hi guys
i have a mysensors with a dht sensor with combined temp and humidity...but im unsure how to use that value
it appears as 17;77
so if i want to do something temp only related say if temp is above 25, how could i do it...i mostly use blocky at this stage....
but in any method im not sure how to seperate this value
dht seperating values
markjgabb
- Domoticz version: 3.8153
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
- emme
- Domoticz version: latest
Re: dht seperating values
for a similar problem with a Temp/Humidity 433 device (for which the otherdevice_temerature does not work) I used this in LUA:
tbTempHum = otherdevices['TEMP_Bagnetto']
for w in (tbTempHum..';'):gmatch('([^;]*);') do table.insert(tbVals, w) end
print(tbVals[1]..' '..tbVals[2])The most dangerous phrase in any language is:
"We always done this way"
markjgabb
Cheers for that.... I'm only just learning lua at the moment. Cam anyone describe to me what exactly that does in the background and foreground
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
