I have some troubles using lua scripts. They aren't working at all, whatever I write. For example here with a dummy switch named "dummy":
if (otherdevices['dummy'] == 'On') then
print ("Hello world")
nothing happen when I switch on/off my device. I already asked big G about my problem, and was able to exclude some of the common issues:
- scripts are in the right folder with right rights
- EventSystem is enabled in Domoticz
I don't really know what to do now, as nothing seems to be logged except "normal" logs...
Here is my configuration:
- Domoticz V3.5877
- Linux raspberrypi 4.4.50-v7+
Thanks in advance for your help
Scripts not being triggered
theplayer777
simonrg
- Domoticz version: 3.8807
Re: Scripts not being triggered
Not sure what is causing your problem is, but a few thoughts.theplayer777 wrote:Code: Select all
commandArray = {} if (otherdevices['dummy'] == 'On') then print ("Hello world") end return commandArray
You are currently using otherdevices, you should use devicechanged instead, otherwise when triggering does work then it would print everytime any device changes and dummy is on, not just when the device changes.
Do you have any other devices apart from dummy?
If you create this script then it will print into the log every time any device changes:
-- /home/pi/domoticz/scripts/lua/script_device_allprint.lua
print("Hello world")
return commandArrayCode: Select all
-- /home/pi/domoticz/scripts/lua/script_device_dummyprint.lua
commnadArray = {}
if devicechanged['dummy'] == 'On' then
return commandArrayRaspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
theplayer777
Thank you for you reply,
I add this dummy switch just to do some testing, but I also tried the same script with another device (door detection) but with the same result. I'm switching the dummy device manually. Nothing special about that, it's just a "default" dummy switch on/off device.
I tried both of your scripts and... I have to say I don't understand why but the 2nd one is working well (even with my dummy device) but the first one isn't doing anything, as expected.... crazy !
simonrg
The first script may just be firing too often and the print is just getting lost.
You could try this version instead, switch off your dummy switch and then create this script
Hopefully dummy should now be turned on.
The second script is the version you want to use anyway, with devicechanged doing the triggering.
-- /home/pi/domoticz/scripts/lua/script_device_allturndummyon.lua
commandArray['dummy'] = 'On'
return commandArrayThe second script is the version you want to use anyway, with devicechanged doing the triggering.
