ser2net with rfxcom : help please
JC38
Post by JC38 »
I would like to test the ser2net feature on my rpi running domoticz.
Today, i've got a RFXCom 433 connected to ttyUSB10 (permanent USB port)
I've set the ser2net.conf like this :
6000:raw:600:/dev/ttyUSB10:38400 8DATABITS NONE 1STOPBIT banner
In Domoticz, I change the hardware RFXCOM - RFXtrx433 USB 433.92MHz Transceiver to RFXCOM - RFXtrx shared over LAN interface
Remote address is set to 127.0.0.1 with port = 6000
After applying this change, i've got this in the log :
2017-03-21 22:19:33.946 Error: RFXCOM: Invalid data received!....
2017-03-21 22:19:49.667 Error: RFXCOM: input buffer out of sync, going to restart!....
Is the line correct into the ser2net.conf ?
Anyone can help please :)
Raspberry Pi 3 Domoticz latest public beta + RFXComm Usb + Aeon Labs Z-Stick + Weather Underground
Windows 2012R2 with Essentials + Domoticz Windows (latest) + Open Hardware Monitor
ImperiHome with mdat / Domoticz for Android
JC38
Re: ser2net with rfxcom : help please
Post by JC38 »
Thank you everyone for your help. :oops:
To avoid the next guy with the same problem and asking the same question obtains the same help, here is the line to add into ser2net.conf :
6000:raw:0:/dev/ttyUSB10:38400 8DATABITS NONE 1STOPBIT
It works when banner is removed
SchattenMann
Post by SchattenMann »
you sir saved my day, thanks
b_weijenberg
Post by b_weijenberg »
here are ser2net instructions for the RFXCOM, see my message of Fri Dec 11, 2015 11:19 am
http://www.domoticz.com/forum/viewtopic.php?f=28&t=192
RFX-433, RFX-433EMC, RFX-868
