How to restart services with python ?
Posted: Saturday 18 March 2017 11:45
by tontze
Hi !
I have a conflict problem with my bt beacon and miflora sensor. Whenever i run miflora update, beacon stops responding, so i thought to restart
beacon service in the end of a miflora python script. How is it easiest to do ?
Re: How to restart services with python ?
Posted: Saturday 18 March 2017 12:44
by ubee
I would have started the beacon service as a systemd service. Then it will be automatically restarted by the Linux system if it terminates for some reason. If you do not know how to start a script as a systemd service, you can find an example on github, bengtner/GPIOinput. You write a small service definition file and put in /etc/systemd/system, then use the systemctl command to enable the service.
Posted: Saturday 18 March 2017 16:38
by tontze
Beaconing is made by this wiki :
http://www.domoticz.com/wiki/Presence_d ... gy_Beacon)
And is it run from init.d
It runs hci0 port, but if anything else accesses it, it will stop responding, im not sure does it die, or just doesnt respond anymore ..
Im noob on this so ..
EDIT: by checking status of a service, i see it is running, but not responding
-T
Posted: Sunday 19 March 2017 10:38
by ubee
I see, since status reports "running" no system surveillance will solve your problem.
I'm sorry, but I can't help you in this matter.
Posted: Monday 20 March 2017 19:29
by tontze
ubee wrote:I see, since status reports "running" no system surveillance will solve your problem.
Ok, thnx anyways, an attempt was made
Does anyone else have ideas ? I simply would like to "sudo /etc/init.d/beqacon restart" service at the end of miflora script. Mi flora is run every 6hours.
I just dont know how to do it with python :/
Posted: Monday 20 March 2017 19:42
by gerardvs
Something like this?
import os
os.system("sudo /etc/init.d/beqacon restart")
Make sure sudo is not asking for a password.
--Gerard
Posted: Tuesday 21 March 2017 13:10
by tontze
gerardvs wrote:Something like this?
import os
--Gerard
Thanks, that did it
Posted: Wednesday 21 June 2017 7:11
by Lora46
Ease from there you'll have the ability to download
Fildo the within the Fildo App. The Fildo Apk could be downloaded.
Posted: Wednesday 21 June 2017 8:35
by devros
hello, iv had same problem as you, so i changed script
with this command
os.system("timeout 2 hcitool lescan 5")
miflora works OK in my tests and it works without sudo
#!/usr/bin/python3
import urllib.request
import base64
import time
import os
from miflora.miflora_poller import MiFloraPoller, \
MI_CONDUCTIVITY, MI_MOISTURE, MI_LIGHT, MI_TEMPERATURE, MI_BATTERY
# Settings for the domoticz server
# Forum see: http://domoticz.com/forum/viewtopic.php?f=56&t=13306&hilit=mi+flora&start=20#p105255
domoticzserver = "XXXX"
domoticzusername = "XXXX"
domoticzpassword = "XXXX"
# So id devices use: sudo hcitool lescan
base64string = base64.encodestring(('%s:%s' % (domoticzusername, domoticzpassword)).encode()).decode().replace('\n', '')
def domoticzrequest (url):
request = urllib.request.Request(url)
request.add_header("Authorization", "Basic %s" % base64string)
response = urllib.request.urlopen(request)
return response.read()
def update(address,idx_moist,idx_temp,idx_lux,idx_cond):
poller = MiFloraPoller(address)
loop = 0
try:
temp = poller.parameter_value("temperature")
except:
temp = 201
while loop < 2 and temp > 200:
print("Patched: Error reading value retry after 5 seconds...\n")
time.sleep(5)
loop += 1
try:
except:
temp = 201
if temp > 200:
print("Patched: Error reading value\n")
return
global domoticzserver
print("Mi Flora: " + address)
print("Firmware: {}".format(poller.firmware_version()))
print("Name: {}".format(poller.name()))
print("Temperature: {}°C".format(poller.parameter_value("temperature")))
print("Moisture: {}%".format(poller.parameter_value(MI_MOISTURE)))
print("Light: {} lux".format(poller.parameter_value(MI_LIGHT)))
print("Fertility: {} uS/cm?".format(poller.parameter_value(MI_CONDUCTIVITY)))
print("Battery: {}%".format(poller.parameter_value(MI_BATTERY)))
val_bat = "{}".format(poller.parameter_value(MI_BATTERY))
# Update temp
val_temp = "{}".format(poller.parameter_value("temperature"))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
# Update lux
val_lux = "{}".format(poller.parameter_value(MI_LIGHT))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_lux + "&svalue=" + val_lux + "&battery=" + val_bat)
# Update moisture
val_moist = "{}".format(poller.parameter_value(MI_MOISTURE))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_moist + "&svalue=" + val_moist + "&battery=" + val_bat)
# Update fertility
val_cond = "{}".format(poller.parameter_value(MI_CONDUCTIVITY))
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + idx_cond + "&svalue=" + val_cond + "&battery=" + val_bat)
time.sleep(1)
# format address, moist (%), temp (°C), lux, fertility
print ("predping")
update("C4:7C:8D:61:B4:DA","142","133","136","143")
