[Noob, so help needed] Sending Telegram message when variable has changed
Zweef
Post by Zweef »
Hi2UAll!
I'm just starting with lua and need some (= a lot) assistance with this. So, please be patient to me! :mrgreen:
Because the best way to learn is to have a goal. So, this is my first goal:
When a variable is changed, send a Telegram message with the content from that variable.
Variable name = HC2_Bewonersstatus (English: Residents status)
The contents will be updated by my Fibaro HC2 Gateway as has got 5 statuses:
Thuis (English: Home)
Slaap (English: Sleeping)
Bewaakt (English: Watched, intended to watch the house if it is uninhibited for some period of time, will be implemented later on)
Weg (English: Away)
Vakantie (English: On Vacation)
So, first I made a new event name:
Telegram (Send), Lua, UserVariable
-- ℹ Initialisation of user settings (change if necessary)
local bot = 'xxxxxxxxx'; -- Telegram Bot ID
local token = 'yyyyyyyyyyyyyy'; -- Telegram Bot Token
local chatId = 'zzzzzzzzzz'; -- Telegram Chat ID
local message = 'This is a test!'; -- Test messages
-- Code (do not change)
print ('Telegram message will be send..');
os.execute('curl --data chat_id='..chatId..' --data-urlencode "text='..message..'"  "https://api.telegram.org/bot'..bot..':'..token..'/sendMessage" ')
print ('Telegram message is send!)';
Step 1: how can I detect the proper variable change, get the content and contruct a message (message = 'Bewonerstatus --> '..HC2_Bewonersstatus)?
Please help, it will be highly appreciated!
Domoticz on Raspberry Pi 3 using mainly Z-Wave
Other gateways:
Fibaro HC2
Athom Homey
jvdz
Domoticz version: 4.107
Re: [Noob, so help needed] Sending Telegram message when variable has changed
Post by jvdz »
Just add an if that looks something like this:
if uservariablechanged['variablename'] then
	-- your logic goes here
Jos
Zweef
Post by Zweef »
jvdz wrote:Just add an if that looks something like this:
Jos
That simple, huh! Thanks Jos.
Just another another question, the commandArray = {} can this be inserted underneath the code-header instead of as first command?
(ie what is this command used for?)
Other gateways:
Fibaro HC2
Athom Homey
jvdz
Post by jvdz »
The commandArray table needs to be returned at each run of an Event script as the internal logic expect it to contain the actions it needs to do after your script ends. In your case you don't add any entry to it as you shell an external process, but it always needs to be returned.
So it really doesn't matter where in your script it is defined, but common practice is to do this at the start of a script.
Jos
Zweef
Post by Zweef »
Clear.
What is the command for getting the contents from a user variable?
In the lua example it's stated:
-- uservariables['yourvariablename'] = 'Test Value'
but that is used to write a content. Do I need
-- userContent = uservariables['yourvariablename']
to get the content?
Other gateways:
Fibaro HC2
Athom Homey
jvdz
Post by jvdz »
Think this is a wiki page that you are interested in and can read all about it: https://www.domoticz.com/wiki/Events#Lu ... _Interface
Jos
Zweef
Post by Zweef »
Thanks.
But it doesn't mention how to get the content from an user variable, as I read right.... :?
Other gateways:
Fibaro HC2
Athom Homey
jvdz
Post by jvdz »
It does but let me help a little:
To retrieve the value of variable TestVariable: uservariables['TestVariable']
To set the variable to a new value: commandArray['Variable:TestVariable']='Some value'
Have fun yet with scripting :-)
Jos
Zweef
Post by Zweef »
jvdz wrote:It does but let me help a little:
Jos
I do have fun, it's like all learning it again from scratch... :D
I really appreciate your time and effort to get me started again!
I just added a selector switch (virtual device) with this 5 options corresponding the 5 status (Home, Away, etc). I though is was handy for testing variable changes. So in the selector action I added (to change the variable):
http://127.0.0.1:8080/json.htm?type=com ... alue=Thuis
That's working! So, that's not the first 'YES!!' I had today. :mrgreen:
So you can say, if have fun!
Other gateways:
Fibaro HC2
Athom Homey
Zweef
Post by Zweef »
Hmm, somehow my code is not triggered (yet)..
local bot = 'xxxxxx'; -- Telegram Bot ID
local token = 'yyyyyyyyyyyyyyyyyyy'; -- Telegram Bot Token
local chatId = 'zzzzzzzzzzzz'; -- Telegram Chat ID
local userVar = 'HC_Bewonersstatus'; -- Uservariable to watch for triggering on change
    -- Watch uservariable for change
local userVarContent = '';
local message = '';
if uservariablechanged[userVar] then
    userVarContent = uservariables[userVar];
    message = 'Bewonersstatus --> '..tostring(userVarContent);
    os.execute('curl --data chat_id='..chatId..' --data-urlencode "text='..message..'"  "https://api.telegram.org/bot'..bot..':'..token..'/sendMessage" ');
    print ('Telegram message is send!');
I will look into it tomorrow what is going wrong. Had enough fun for today.... ;)
Other gateways:
Fibaro HC2
Athom Homey
lemassykoi
Domoticz version: 2025.1
Post by lemassykoi »
If your script is in LUA, maybe you should remove all the ; you put everywhere ? ;)
also, you should use :
commandArray[1]={['Variable:userVarContent'] = userVar}
to update your user variable
jvdz
Post by jvdz »
lemassykoi wrote:If your script is in LUA, maybe you should remove all the ; you put everywhere ? ;)
Agree it isn't needed but it shouldn't cause any issues either.
lemassykoi wrote: also, you should use :
I assume the JSON call is done from the external HC system, but either way, it is required to do the update through a JSON call as updating a variable through the event system will not trigger any script_variable_xyz.lua scripts.
Jos
Zweef
Post by Zweef »
The variable is updated by the Fibaro HC2 controller (through Domoticz API-command, JSON call).
I do this to because in the LUA early days it was needed. Just want to write/learn code by being as accurate/complete as possible. I know it's not needed. Just being a purist. :mrgreen:
Jos
You complete lost me here... :shock:
Do you mean when a variable is changed by an other source then Domoticz, nothing will be triggerd?
Can you please explain?
Other gateways:
Fibaro HC2
Athom Homey
jvdz
Post by jvdz »
Zweef wrote: You complete lost me here... :shock:
It is the other way around.
When you update a variable with:
the event system will update the variable but will not trigger any script_variable_*.lua event scripts.
script_variable_*.lua event scripts are only triggered when the variable is updated through JSON. I think this was done to avoid an indefinite loop but honestly see no difference with variables and devices as the same is possible for devices.
See another topic with some more information on this similar question: viewtopic.php?f=6&t=14745&p=108042#p108042
Not sure if anything has changed on the latest version of domoticz, but assume somebody will chime in when this is the case.
Jos
Zweef
Post by Zweef »
Okay!
Learning all the time, learning all the time.... 8-)
Thanks a lot, Jos!
Other gateways:
Fibaro HC2
Athom Homey
