set POPP thermostat error
gegges
Domoticz version: 3.8153
Post by gegges »
do you have have an idea why this small blockly creates an error? I reduce it to the minimum and use the time as a trigger (>= 07.00)
I want to set the temperatur in my bathromm (Bad) of my POPP thermostat and get´an error
2017-03-11 07:48:00.045 EventSystem: Event triggered: Bad_1
2017-03-11 07:48:00.045 Error: EventSystem: Malformed action sequence!
I tried the similar with sending an email - this is working.
2017-03-11 07:48:00.045 EventSystem: Event triggered: notifi_1
2017-03-11 07:48:01.840 Notification sent (Email)
Thx´s a lot for your help.
cheers Thomas
using Raspberry Pi / Aeotec ZW090 Z-Stick Gen5 Version: 1.4-2501-g5af6780-dirty/ RFXCOM - RFXtrx433 USB 433.92MHz Version Ext2/1022
K3rryBlue
Domoticz version: V4.10xx
Re: set POPP thermostat error
Post by K3rryBlue »
If i recall correct, you can't use xxxxxactual to define a setting.
You should use
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
gegges
Post by gegges »
thx´s.
I´ll upgrade to the latest beta (3.6944). I´m still running Version: 3.5877 and it´s not included.
gegges
Post by gegges »
Hello, I updated to the beta Version: 3.7349.
I don´t see the option "setpoint" inside blockly.
Setpoint works directly/manually with the Danfoss Popp Radiator before and after update.
I see at this link http://www.domoticz.com/forum/viewtopic ... 78#p108045 how it should look like inside blockly (the menuoption at the bottom).
Is there a config option in general to enable the "setpoint" or any other ideas?
thx´s in advance
cheers Thomas
gegges
Post by gegges »
addendum: my devices are subtype: setpoint
POPP setpoint.PNG (13.55 KiB) Viewed 1274 times
