RFXtrx433 doesn't view Chuango motion sensor
Posted: Friday 10 March 2017 10:46
by bigpea
I have the "RFXCOM - RFXtrx433 USB Transceiver 433.92MHz" Version: Ext / 1015.
I have also the CHUANGO alarm system and with the trx I can view them all devices (door sensor and remote control) but not the motion sensor (code 67320071).
I tryed also to press the tamper button and more solutions, but i can not see the motion sensor.
Do you have any idea?
Thanks.
Re: RFXtrx433 doesn't view Chuango motion sensor
Posted: Friday 10 March 2017 10:51
by b_weijenberg
To receive Chuango as security sensor use Ext2 firmware and enable Lighting4 and X10.
Contact support rfxcom.com if the motion sensor is not received with Ext2.
Posted: Friday 10 March 2017 11:04
by bigpea
Ok thanks, i will try this evening.
Posted: Friday 10 March 2017 21:52
by bigpea
Unfortunatelly this solution doesn't work.
I installed the EXT2 1016 firmware and I enabled Lighting4 and X10 but i don't see nothing.
I will contact the support. many thanls.
Posted: Friday 17 March 2017 14:42
by b_weijenberg
Insert the jumpers D1 and D2 to receive the Chuango motion sensor as X10 motion sensor.
Insert jumpers D0, D1 and D2 to receive the Chuango door sensor as X10 door sensor.
Posted: Monday 20 March 2017 11:18
by bigpea
Probably the sensor that I was damaged, but it worked properly with the unit.
With a new sensor works well.
