RFXtrx433 doesn't view Chuango motion sensor
bigpea
Post by bigpea »
I have the "RFXCOM - RFXtrx433 USB Transceiver 433.92MHz" Version: Ext / 1015.
I have also the CHUANGO alarm system and with the trx I can view them all devices (door sensor and remote control) but not the motion sensor (code 67320071).
I tryed also to press the tamper button and more solutions, but i can not see the motion sensor.
Do you have any idea?
Thanks.
b_weijenberg
Re: RFXtrx433 doesn't view Chuango motion sensor
Post by b_weijenberg »
To receive Chuango as security sensor use Ext2 firmware and enable Lighting4 and X10.
Contact support rfxcom.com if the motion sensor is not received with Ext2.
RFX-433, RFX-433EMC, RFX-868
bigpea
Post by bigpea »
Ok thanks, i will try this evening.
bigpea
Post by bigpea »
Unfortunatelly this solution doesn't work.
I installed the EXT2 1016 firmware and I enabled Lighting4 and X10 but i don't see nothing.
I will contact the support. many thanls.
b_weijenberg
Insert the jumpers D1 and D2 to receive the Chuango motion sensor as X10 motion sensor.
Insert jumpers D0, D1 and D2 to receive the Chuango door sensor as X10 door sensor.
bigpea
Post by bigpea »
Probably the sensor that I was damaged, but it worked properly with the unit.
With a new sensor works well.
