2 zwave controllers
Posted: Sunday 05 March 2017 21:56
by ropske
Hi, i have a working Pi B+ with Aeon Labs Z-Stick S2 and multiple sensors (all working fine)
now i bought the Pi3 and a Aeotec ZW090 Z-Stick Gen5
Now i want to add all my sensors that are in pi b+ into the Pi3
So i'm putting my ZW090Gen5 zwave stick in adding mode and i want to add my zwave sensors 1 by 1
but this is not working
Can zwave sensors not be bound to multiple controllers?
If i exclude a sensor from my pi b+ and add to the pi3, then it works.
But i want to shutdown my old pi b+ when my Pi3 is fully operational, not before. So first i want all sensors to be added, then i can upload all my scripts and shutdown the old pi B+
Someone has a reason why this is not working? Thank you
Re: 2 zwave controllers
Posted: Sunday 05 March 2017 22:13
by Egregius
Exclude everything from the old, include in the new. Couple of hours work and you're back up running.
Posted: Sunday 05 March 2017 22:28
by ropske
thanks Egregius, thought that would be the only solution :p
was just hoping i could begin starting with it now, but the old setup is still working; because i wont be able to manage the whole setup by tonight and then my heating (your heating script ;) will not be running then tomorrow morning and i'm pretty sure my wife will be upset, haha
so will start tomorrow evening :D
Posted: Sunday 05 March 2017 23:06
by Ericv
I never tried it, but i think it is possible to have 2 controllers in a zwave network. And then you can sent the configuration from one controller to the other. That must be a way to transfer your configuration from piB ro pi3.
Posted: Monday 06 March 2017 19:29
by Domosapiens
To do a network shift between controllers, you will need to start off by including the Z-Stick Gen5 into the Z-Stick S2 network.
First download the Zensys Tool which will be a very helpful tool in achieving many of these steps
https://aeotec.freshdesk.com/solution/a ... ensys-tool
Read more here:
https://aeotec.freshdesk.com/support/so ... -z-sticks-
Posted: Monday 06 March 2017 21:38
by chrisfraser05
I have domoticz running as a secondary controller to my vera.
I just added the stick onto Domoticz then under setup I selected "recieve configuration from another controller" or similar.
On the vera I just added a generic device.
Once included I have the option on Domoticz to do a controller shift, I guess it would just be a case of telling one to transfer primary role and the other to recieve configuration.
Posted: Thursday 09 March 2017 9:26
by ropske
Hi Domosapiens, i tried to use this and the including and shifting and all worked with the tool.
But when i plugged my new Z-Stick Gen5 in my new pi3 and added a zwave device, all idx where added (the amount was correct)
but a lot of them showed unknown and etc.
Gonna try again tonight, maybe my openzwave is an old one on my new pi3
(should not may happen as i did a clean install according to the wiki pages, but will check again and try)
Posted: Friday 10 March 2017 22:24
by Domosapiens
Names are not transferred, because they are not on the stick.
You have to name them by hand (as on the other stick)
