Battery Notifications
getSurreal
Post by getSurreal »
Added a new script option for getting notifications for low battery status of devices.
https://www.domoticz.com/wiki/Battery_level_check
This script will execute once a day at the time that you specify. It will check all your used devices and send an email with a list of all devices below the battery threshold. Optionally you can also receive a weekly summary of all your battery devices and their current battery level regardless of the threshold.
This script will run on Linux or Windows and does not require an external json parsing library. It uses the json library provided with Domoticz. It also doesn't need to write any temporary json files to disk.
Re: Battery Notifications
@getSurreal,
I am using the dzVent LUA script supplied as an example of the ease of use of dzVents to check the battery status of all relevant devices. Would that be something to add to the wiki ?
local BATTERY_THRESHOLD = 10
	active = true,
		['timer'] = 'every hour'
	execute = function(domoticz)
		local message
		-- first filter on low battery level
		local lowOnBat = domoticz.devices.filter(function(device)
			local level = device.batteryLevel
			return (level ~= nil and -- not all devices have this attribute
					level ~= 255 and -- probably means something like 'not applicable'
					level <= BATTERY_THRESHOLD)
		end)
		-- then loop over the results
		lowOnBat.forEach(function(lowDevice)
			message = message .. 'Device ' ..
					lowDevice.name .. ' is low on batteries (' .. lowDevice.batteryLevel .. '), '
		end)
		if (message) then
			domoticz.notify('Low battery warning', message, domoticz.PRIORITY_NORMAL)
			domoticz.log('Low battery warning: ' .. message, domoticz.LOG_ERROR)
getSurreal
Posting it there could help others in the future. I don't know if it needs to be run differently, but right now it doesn't work for me. I get the following error.
Error: EventSystem: Lua script test did not return a commandArray
If it works, it could have saved me a lot of time vs rewriting the other example that's on the wiki.
getSurreal
I didn't know what DZvents was at first. In this case I don't think that script should go in the same place on the wiki and just kept with DZvents.
I do need to look more into DZvents though. Looks nicer.
bimse
Domoticz version: Model 3
Post by bimse »
I use 'Alternate LUA script' but get this message.
To require password, how insert this.
Error: Event System: In script_time_battery: /home/pi/domoticz/scripts/lua/JSON.lua:660: html passed two JSON: Decode ():
401 UNAUTHORIZED
Some suggestions
Translated with google
getSurreal
Not sure how to pass username and password through the script and not typically good practice to add credentials into a script. I suggest adding an exception for your domoticz server to be able to connect to itself without a password. This is in the domoticz settings system tab.
bimse
Post by bimse »
without password it works
thanks
Derik
Post by Derik »
Is this working for all sensors? Zwave include?
L2v2P
Post by L2v2P »
The daily low battery report sends an empty e-mail every day (because all battery levels are above the threshold). Is there a way to prevent the e-mail from sending when all battery levels are above the threshold?
L2v2P
Post by L2v2P »
L2v2P wrote:The daily low battery report sends an empty e-mail every day (because all battery levels are above the threshold). Is there a way to prevent the e-mail from sending when all battery levels are above the threshold?
Think I fixed it by checking if the Message variable contains any data:
if Message ~= '' then
	commandArray['SendEmail']='Domoticz Battery Levels#'.. Message .. '#' .. EmailTo
CLEMENT99
Post by CLEMENT99 »
getSurreal wrote: Friday 03 March 2017 21:02 This script will run on Linux or Windows and does not require an external json parsing library. It uses the json library provided with Domoticz. It also doesn't need to write any temporary json files to disk.
I'm running this script under windows but I get an error :
EventSystem: in Battery_check: [string "-- ========================================= ..."]:49: attempt to index global 'devices' (a nil value)
CLEMENT99
Post by CLEMENT99 »
I found the problem, it was a bad copy of quotes in the io.popen command but now, i get this error:
Error: EventSystem: in Battery_check: [string "-- ========================================= ..."]:49: attempt to index global 'devices' (a nil value)
That's at the line :
for i,device in ipairs(devices.result) do ....
    handle = io.popen("curl 'http://" .. Domoticz .. ":" .. DomoticzPort .. "/json.htm?type=devices&order=name'")
    devicesJson = handle:read('*all')
    handle:close()
    devices = json:decode(devicesJson)
    BattToReplace = false
            if device.BatteryLevel < BatteryThreshold and device.Used == 1 then
            Message = Message .. device.Name .. ' battery level is ' .. device.BatteryLevel .. '%<br>'
            print(device.Name .. ' battery level is ' .. device.BatteryLevel .. '%')
This time, I don't find the issue. :(
CLEMENT99
Post by CLEMENT99 »
I just found that the option to a send message when battery low level is low is already implemented in Domoticz.
Just go to settings/Other tab and change the Battery low level value.
Definitively, great product ..
:oops:
