dzVents How to translate standard LUA functions into a dzVents script
jake
Post by jake »
I started using dzVents because of the easy possibility to add delays to actions. I am in need of that since controlling my Onkyo receiver asks for some patience (especially after the switch-on command). Although a simple switch-on and off dzVents script works fine, I think I don't get it how to translate the original LUA functions into a dzVents script.
This is a snip from a standard LUA script file that I use for the longest time within Domoticz:
-- function to get information from receiver
 function onkyo_status(command)
  local result = {}
  local output = io.popen ('onkyo '..command)
  for line in output:lines() do
  table.insert(result, line)
 output:close()
 return result
-- function to change settings receiver
 function onkyo_change(command)
 os.execute('/usr/local/bin/onkyo --host '..onkyohostip..' --port '..onkyohostport..' '..command)
dannybloe
Re: dzVents How to translate standard LUA functions into a dzVents script
Post by dannybloe »
Well, dzVents is just plain old Lua with an added API to control your Dz instance so nothing prevents you from just calling this function. Simply place it somewhere in your script file:
	local result = {}
	output:close()
	return result
    active = true,
    	local result = onkyo_status('mycommand')
jake
Post by jake »
dannybloe wrote:Well, dzVents is just plain old Lua with an added API to control your Dz instance so nothing prevents you from just calling this function. Simply place it somewhere in your script file:
Thanks, it indeed works as you explain.
To reuse functions and local variables as many times in 1 script file (to only have to declare them once and don't have everything multiple times), can I do something like this in 1 script file?
        active = true,
            'test'
        execute = function(domoticz, switch1)
            if (switch1.state == 'On') then
                domoticz.notify('Hey!', 'I am on!',
                domoticz.PRIORITY_NORMAL)
                domoticz.notify('Hey!', 'I am off!',
        active = true,
            'test2'
        execute = function(domoticz, switch2)
            if (switch2.state == 'On') then
dannybloe
Post by dannybloe »
No, you cannot do that. If you want to reuse stuff you can make a module yourself and require that in all your scripts. If you do a google search for 'lua modules' you get loads of exampels. It really easy and straightforward. You can also look at how dzVents loads the modules. Just search the code for 'require' (and you may have to set some path variables).
jake
Re: RE: Re: dzVents How to translate standard LUA functions into a dzVents script
Post by jake »
dannybloe wrote:No, you cannot do that. If you want to reuse stuff you can make a module yourself and require that in all your scripts. If you do a google search for 'lua modules' you get loads of exampels. It really easy and straightforward. You can also look at how dzVents loads the modules. Just search the code for 'require' (and you may have to set some path variables).
Thanks for pointing me into the right direction. It works great so far!
I only had to move my library away from from domoticz\scripts\lua\scripts to domoticz\scripts\lua instead. In the dzVents script folder, dzVents expect a proper script file instead of a library module. To my surprise LUA/dzVents was able to trace down my library file in the \lua folder without a specific path to it.
dannybloe
Post by dannybloe »
That is because there are a couple of registered paths where LUA searches for modules. You can extend that list with more paths. That is what dzVents does in one of it's scripts. Somewhere at the beginning.
