Hi All,
I'm interested in writing a plugin myself. So I've installed a spare Pi with the latest Raspbian (using NOOBS).
Updated using apt-get update and apt-get upgrade
Installed Domoticz (used the method as stated in the Wiki), and issued a updatebeta to get to the latest Beta release (3.6807)
Domoticz is up and running.
I noticed that de plugin directory was created, but is empty and has (in my opinion) the wrong access rights (or owner).
It actually was owned by root.root and had no access fro the Pi account, that Domoticz is actually running under.
So I used chmod a+rwx to make the directory accessible to Domoticz (could also have used chown pi.pi).
To test the plugin framework, I've downloaded the Denon example, and put in in the Denon4306 folder in the plugins directory (renamed to plugin.py).
Restarted Domotics.
The plugin is now listed in the add hardware section, but if I try to add it, actually nothing happens (I'ts actually not added, so not listed in the table in the hardware section). I also noticed, there is no config, other than the data timeout option.
Same happens if I try to use the base template as a test.
Is this a bug I hit? Or am I doing something wrong here?
The log shows no errors.
Thanks in advance for any help.
Adding plugin does not work
- ycahome
- Domoticz version: lat Beta
Re: Adding plugin does not work
Hello jorgh and welcome.
Just some hints:
- "plugins" folder seems that is normally without permisions. I always getting in with "sudo -s".
- "plugin.py" file should be on a subfolder inside "plugins" folder. You can easily find out the name on the "plugin.py" file in keyword "key=". Try to keep the case intact.
- You can always check Log to see what goes wrong.(Setup/Log)
Hope this helps,
Just some hints:
Hope this helps,
https://www.youtube.com/siakavelisgr
- jorgh
- Domoticz version: 3.8224
ycahome,
Thanks for your response.
So I'm still puzzled...
I agree, that this is the case. But I doubt that it should be, it's the only folder owned by root in the compete domoticz install. I've corrected this, but I think this might need to be changed in the Domoticz install script. However, as the plugins are listed in the drop-down, I think there is no permission issue with the way I've set it up right now.Just some hints:
Verified, and yes, this is the case.- "plugin.py" file should be on a subfolder inside "plugins" folder. You can easily find out the name on the "plugin.py" file in keyword "key=". Try to keep the case intact.
Well, the strange thing is, that nothing strange shows up there, don't know if there is a way to enable extended logging.- You can always check Log to see what goes wrong.(Setup/Log)
- jorgh
All,
Just tried using Internet Explorer instead of Chrome.
Using Internet Explorer it works, another thing I noticed, that in de drop down, in IE, the list is sorted Alphabetically and In Chrome, the Python plugins are always on the bottom of the list.
So, there seems some incompatibility issue with Chrome. Strange thing is, that adding other hardware works perfectly in Chrome.
Regards,
Regards,
- ycahome
my Chrome 56.0.2924.87 displays the plugins the same way like firefox and IE.
Try to purge browser's cache.
- jorgh
@ycahome,
Purging the cache does not solve the issue.
For now, I'll just use IE as this works for me.
Regards,
Jorg
Regards,
Jorg
