Timeout Notification with Philio Pan04 - Help wanted
Ady92100
Domoticz version: >V3.6796
Post by Ady92100 »
Hello everybody
I have installed two "Philio Technology Corporation PAN04-1 Double Relay Switch 2x1.5kW with Power Measurement", with 1 controller Aeotec DSA02203 Z-Stick S2 and another switch = Aeotec DSC18103 Micro Smart Switch (2nd Edition).
For the two PanO4-01 switch, I received many times per hour this kind of message "OpenZWave: Received timeout notification from HomeID: 25483669, NodeID: 6 (0x06)". However, most of the time, DZ works.
Two switches are in the same room, both less than 4m from the USB stick which is connected to a Synology DS212 with a 1m cable.
I've checked the network. (There is also a repeter in the room).
I've also checked the philio.xml file description. it seems ok.
And sometimes, there are so many "timeout notification" messages, that the all z-wave network hang up and the other z-wave switch sends also "timeout notification" message. Then I have to issue a "soft reset of the controler". and it heals the network for a few days.
I don't know, what to do and what to check.
Do you have any advice ?
I've also read a note in a forum explaining that philio switch are not so good hardware. What do you think of that ?
Thanks in advance for your help/advice.
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
juankar
Domoticz version: 4.
Re: Timeout Notification with Philio Pan04 - Help wanted
Post by juankar »
Philio is not a good quality device, it is my experience. I had the same issue, lot of timeouts (until devices dead). If you can, try to return this device to the commerce where you bought them.
Good luck,
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
The big difference for me was going from S2 stick to Gen 5 stick.
In my case controller (1) is added to group 2 and 3 also.
You could give it a try.
Also ..think in the line of sight of your switch towards the controller.
Any metal shielding in that line? The PAN04 build-in under a metal shield ?
My 3 PAN04's are working great.
