Nested IF blocks
micha_pr
Nested IF blocks
Post by micha_pr »
if nested "If" blocks do not work at all - is it possible to disable this option in Blockly?
(we didn't know it before - and it have taken long time while we understood this issue)
I think a lot of users can try to use it - and can not understand it, what happen ;)
(BTW: is this a "missing feature" - or by design?)
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
rotero
Domoticz version: V2.2284
Re: Nested IF blocks
Post by rotero »
I also found out nested Blockly scipts are not working! Very annoying!
What I think is also different with Blockly:
Normally if you use an IF DO / ELSE IF DO statement, the ELSE IF is only checked if the first IF is not true.
Blockly works different.
Example:
If all variables are 0 and the time is 17:00, all variables will be set to 1 with this script:
IF time > 13:00
DO set A = 1
ELSE IF time > 13:30
DO set B = 1
ELSE IF time > 14:00
DO set C = 1
ELSE IF time > 15:00
DO set D = 1
I always thought that only one DO can be executed in these kind of statements.
Regards,
Rob
micha_pr
Post by micha_pr »
Right. You should use the full condition again in the "else" if.
It is really not an ELSE IF ... but an "OR IF"
Michael Pruefer
