Virtual switch to change device parameter
Posted: Sunday 19 February 2017 17:19
by jaha
I wanna make a virtual device (switch) that changes a device parameter of my fibaro wall plug (the led ring) Is this possible and how?
Thanks in advance!
Re: Virtual switch to change device parameter
Posted: Monday 20 February 2017 11:08
by jaha
In vera you could send this via lua is there a smilar way in domoticz? luup.variable_set( "urn:micasaverde-com:serviceId:ZWaveDevice1", "VariablesSet", "12,1d,15", 48 )
Posted: Thursday 23 February 2017 19:54
by jaha
Bump, anybody?
Posted: Thursday 23 February 2017 22:53
by Nautilus
jaha wrote:Bump, anybody?
Did you try searching? There's been some discussion about this before, at least:
viewtopic.php?f=4&t=15141&p=111305&hili ... ng#p111305
viewtopic.php?t=8605
Hope this helps
Posted: Friday 24 February 2017 15:51
by jaha
Thank you got it working when I paste the url in the browser byt cant got i working with a switch action or a switch selector by trying to post this:
https://127.0.0.1/json.htm?type=command ... lvbg%3D%3D
Should https work with switch actions? I also have excluded the 127.0.0.* from auth.
Posted: Friday 24 February 2017 21:17
by Nautilus
Sorry, I don't use it myself so no idea to advance the cause further
Is http
s necessary by the way?
Posted: Sunday 26 February 2017 12:05
by jaha
Is http
Yes of course its encrypted
Re: RE: Re: Virtual switch to change device parameter
Posted: Sunday 26 February 2017 16:32
by RayAmsterdam
Is http
Why do you want to encrypt it when you keep the command in your own network, even on the same machine??
Posted: Sunday 26 February 2017 16:34
by RayAmsterdam
Btw, I am missing the port number in your json URL.
Posted: Sunday 26 February 2017 19:19
by jaha
RayAmsterdam wrote:Btw, I am missing the port number in your json URL.
Just like the extra protection if somebody unlikely would hack in to my network. (I'm a network engineer) Tried with the port but doesn't help using default 443 for SSL.
