A sdcard friendly config on Raspberry
PBdA
Domoticz version: 3.5893
Post by PBdA »
Domoticz tends to write often on disk. When disk is a sdcard it is better to avoid to write too often. The idea is to mount /tmp in ramdisk and have Domoticz to work in /tmp
Config: Raspberry Pi 3 with Raspbian Jessie.
I start Domoticz with systemd. File is /etc/systemd/system/domoticz.service :
[Unit]
Description=Domoticz home automation
After=network.target
[Service]
ExecStartPre=/usr/local/bin/set-domoticz start
ExecStart=/opt/domoticz/domoticz -www 81 -sslwww 0 -dbase /tmp/domoticz.db
ExecStopPost=/usr/local/bin/set-domoticz stop
Restart=always
[Install]
WantedBy=multi-user.target
Bash script /usr/local/bin/set-domoticz gets a valid DB at start and save DB to disk at stop :
#! /bin/bash
# path to adapt
domoticzdir="/opt/domoticz"		# where lives Domoticz
db="/tmp/domoticz.db"			# BD path in a tmpfs filesystem
ozwlog="/tmp/OZW_Log.txt"		# OpenZwave log path in a tmpfs filesystem
heartbeat="/tmp/domoticz.heartbeat"	# heartbeat file for watchdog
bckbase="$domoticzdir/backups/hourly/backup-hour-"
checkdb() {
	if [ "$(sqlite3 -batch -bail -cmd 'pragma integrity_check;' -cmd '.quit' $1 2> /dev/null)" == ok ]; then
		rm -f $1-shm $1-wal
		return 0
	fi
	return 1
case "$1" in
	 start)
		touch $heartbeat
		rm -f $domoticzdir/Config/OZW_Log.txt
		ln -s $ozwlog $domoticzdir/Config/
		[ -e $db -a checkdb $b ] && exit 0	# DB exists and is OK
# looking for a working DB, newer first
		for f in $(ls -t $bckbase*.db); do
			if checkdb $f; then
				cp -a $f $db
				exit 0
			fi
		done
	stop)
# save DB if it is OK
		[ -f $db ] && checkdb $db && cp -a $db $bckbase$(date "+%H").db ||  exit 1
esac
exit 0
Domoticz saves the on disk every hour. It's OK for me if I lost an hour of measure.
File heartbeat is for watchdog. For watchdog to monitor Domoticz, put in an lua script _time_XXX.lua :
-- pour le watchdog
file = io.open("/tmp/domoticz.heartbeat", "w")
file:close()
and in /etc/watchdog.conf :
file = /tmp/domoticz.heartbeat
change = 300
Watchdog can be dangerous: if things go wrong, Raspberry can reboot continuously. To avoid continuous reboot, I add to rc.local :
# BdA added for the watchdog
lbf="/root/lastboot"
actuel=$(date +%s)
if [ -f "$lbf" ]; then
  last=$(cat "$lbf")
  if (( actuel - last < 120 )); then
    systemctl stop watchdog
  fi
fi
echo $actuel > "$lbf"
date | mailx -s "Raspberry $(hostname) boot" [email protected]
PBdA
MasterCATZ
Re: A sdcard friendly config on Raspberry
Post by MasterCATZ »
-- pour le watchdog
file:close()
you have me lost at this stage
I do not know where to add this code what is the file name/location?
Also for some reason, the hourly backups are not working the DB is been written to the ramdrive (/tmpfs), but no DB sync is happening (home/pi/domoticz), also it is not grabbing the existing DB that is already written to disk.
sudo nano /etc/fstab
tmpfs   /tmpfs    tmpfs    defaults,noatime,nosuid,mode=0755,size=128m    0 0
sudo nano /usr/local/bin/set-domoticz
#! /bin/bash
# path to adapt
domoticzdir="/home/pi/domoticz"      # where lives Domoticz
db="/tmpfs/domoticz.db"         # BD path in a tmpfs filesystem
#ozwlog="/tmpfs/OZW_Log.txt"      # OpenZwave log path in a tmpfs filesystem
heartbeat="/tmpfs/domoticz.heartbeat"   # heartbeat file for watchdog
checkdb() {
      rm -f $1-shm $1-wal
      return 0
   fi
   return 1
case "$1" in
    start)
      touch $heartbeat
         if checkdb $f; then
            cp -a $f $db
            exit 0
         fi
      done
   stop)
esac
exit 0
sudo nano /etc/systemd/system/domoticz.service
[Unit]
[Service]
ExecStart=/home/pi/domoticz/domoticz -www 8080 -sslwww 0 -dbase /tmpfs/domoticz.db
Restart=always
[Install]
is their another program I need to install or something?
PBdA
Post by PBdA »
/etc/watchdog.conf config file tells watchdog that file /tmp/domoticz.heartbeat should not older than 300 seconds. LUA time script renew file every minute. That way, if domoticz hangs for some reason, watchdog will reboot Raspberry after 5 minutes.
PBdA
MasterCATZ
Thanks for the fast reply, and the code to build from,
I edited the original post so that you might be able to help fill in the information I am missing
I have no idea what to do with the lua code
and unsure why the db is not being synced
my temp path is tmpfs and my domoticz location is /home/pi/domoticz
pi@raspberrypi:/tmpfs $ ls -lart
417792 Jul 15 08:32 domoticz.db
total 4468
drwxr-xr-x 23 root root    4096 Jul 15 05:47 ..
-rw-r--r--  1 root root       0 Jul 15 07:35 domoticz.heartbeat
-rw-r--r--  1 root root   32768 Jul 15 07:40 domoticz.db-shm
drwxr-xr-x  2 root root     120 Jul 15 07:40 .
-rw-r--r--  1 root root  417792 Jul 15 08:32 domoticz.db
-rw-r--r--  1 root root 4120032 Jul 15 08:33 domoticz.db-wal
pi@raspberrypi:~/domoticz $ ls -lart
487424 Jul 15 05:47 domoticz.db
total 10896
-rw-r--r--  1 pi   pi      35147 Nov 14  2016 License.txt
-rw-r--r--  1 pi   pi       4347 Nov 14  2016 domoticz.sh
-rwxr-xr-x  1 pi   pi        600 Nov 14  2016 updaterelease
-rwxr-xr-x  1 pi   pi        583 Nov 14  2016 updatebeta
-rw-r--r--  1 pi   pi       3414 Nov 14  2016 server_cert.pem
drwxr-xr-x  4 pi   pi       4096 Feb  3 02:05 plugins
drwxr-xr-x  8 pi   pi       4096 Apr 16 23:05 scripts
-rw-r--r--  1 pi   pi      84349 Jul  2 00:05 History.txt
drwxr-xr-x 13 pi   pi       4096 Jul  5 23:41 www
-rwxr-xr-x  1 pi   pi   10492848 Jul 10 19:07 domoticz
-rw-r--r--  1 pi   pi     487424 Jul 15 05:47 domoticz.db
drwxr-xr-x  5 root root     4096 Jul 15 07:00 backups
drwxr-xr-x  7 pi   pi       4096 Jul 15 07:29 .
drwxr-xr-x 73 pi   pi       4096 Jul 15 07:35 Config
drwxr-xr-x 26 pi   pi       4096 Jul 15 07:35 ..
-rw-r-----  1 root root      236 Jul 15 07:42 domocookie.txt
I have decided to change
to
bckbase="$domoticzdir/backups/RAM/backup-hour-"
as I think domoticz internal backup is over writing the scripts backup
the other thing I have done is changed all file permissions, so will see how this goes when I am shopping
I am needing to data log 50 temp sensors 1 sec polling
*edit* still no hourly backup has been made
/home/pi/domoticz/scripts/lua
is this where you make a file called
Egregius
Domoticz version: v2024.7
Post by Egregius »
PBdA
Post by PBdA »
Lua script should be placed in directory /home/pi/domoticz/scripts/lua/ and is name should like script_time_xxxx.lua
To be more simple, my scripts rely on Domoticz backups. Backupdir is the place where Domoticz put the backups: /home/pi/domoticz/backups/ and automatic backups should be enabled in Domoticz settings.
PBdA
PBdA
Post by PBdA »
And also domoticz.service should be enabled at boot by command:
systemctl enable domoticz.service
To avoid a reboot you can start it first time by command:
systemctl start domoticz.service
PBdA
MasterCATZ
I'll keep poking around
what I might end up doing is a sync using google drive or something
just unsure why I can not get it to load up the last db on restart
if your using the internal backup I might have thought of the problem
this is where the backup files are put
/home/pi/domoticz/backups/hourly
this might need to go another directory deep
bckbase="$domoticzdir/backups/backup-hour-"
so I will give this ago
MasterCATZ
huge facepalm I don't have sqlite3 actually installed :oops:
all working sweet :roll:
Users browsing this forum: Ahrefs [Bot] and 1 guest
