Hi There,
my Domoticz is running flawlessly as a http server.
I however decided it was time to switch to ssl encryption.
Therefore I tried creating a ssl certificate using the following instructions
http://www.domoticz.com/wiki/Native_sec ... ts_Encrypt
When trying to validate the certificate i end up with a socket error errno13 permission denied.
I also tried the secon method to create and validate in one go with
sudo ~ ./letsencrypt certonly --webroot --email <your email> -d <your domain name> -w <user home>/domoticz/www/
in that case I get an error:
Could not connect to (mydomain)
The Domain is working without a problem. The Ports 80/443/8080 are forwarded to the raspberryand I am able to connect to port 8080 with http and port 443 with https.
I don not understand why I have to forward port 80, cause nothing is listening on that Port.
any Idea what I am doing wrong?
Problems setting up ssl certificate
