Dymond led strip - warm white
krizzz
Post by krizzz »
Does anyone know, which protocol to use with the Led strip from dymond? I tried some protocols on my RFXcom but did not seem to pick up.
http://www.dymondgroup.be/?portfolio=wa ... key-remote
Eigenschappen:
- 300x EPISTAR LED (60×5) 3528 SMD 5 meters
- Light angle: 120 degreesHours: >25,000 hours
- PCB color: White
- Tape: 3M electric industrial
- Cuttable every 3 LED’s or every 5 cm
- Operating temperature: -10 ~ +40 degrees
- Voltage: 12VIP gradation: IP65 PU waterproof
- Color temperature: 2700K~3000K (Kelvin)
- Lumen: Max. 1200 Lumen
SweetPants
Re: Dymond led strip - warm white
Post by SweetPants »
First question you should ask yourself "Is it in the supported device list" (see RFXcom site)
Answer: No, because the remote uses IR, not 433Mhz
krizzz
Post by krizzz »
You are right. I checked the list and indeed no availability of this product. But that doedny mean it will not work :). But if it works on IR, then it is a Done deal! Thanks for your help.
