wh1080 usb Weather Station
adenos
Domoticz version: 3.5877
Post by adenos »
I am a Newbe to Domoticz so excuse me when this is a silly question.
Does anyone have a solution to implement a WH1080 into Domoticz? (Alecto)
I have tested it with CumulusMX and all worked fine.
When I look at the USB connection I see the following:
sudo lsusb -v -d 1941:
Bus 001 Device 004: ID 1941:8021 Dream Link WH1080 Weather Station / USB Missile Launcher
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x1941 Dream Link
idProduct 0x8021 WH1080 Weather Station / USB Missile Launcher
bcdDevice 1.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 52
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
Device Status: 0x0000
(Bus Powered)
Thanks in advance.
Toulon7559
Domoticz version: <2025
Re: wh1080 usb Weather Station
Post by Toulon7559 »
Have you tried to 'brutely' connect your Domoticz-computer and your WH1080 by means of the USB-interface, with at the Domoticz' Dashboard the Hardware set to "TE923 USB Compatible Weatherstation"?
If OK = appearance of the Weather-station as device in the list of Devices. If not automatically switched on, then activate (= switch arrow-icon from green to blue) = ready-to-go with Domoticz & WH1080
USB is cheap, but requires a cable. As a (more expensive) wireless alternative you could tap the wireless transmissions from the sensors by means of an RFLinkGateway hooked to Domoticz: see List of Devices
brucez
Post by brucez »
Hi!
I have the same weather station. I have plugged it in, but I can't get it to work by usb. :(
It says:
Error: TE923: Weather station not found.
Any idea? Does it work for anyone?
Thanks! :)
