Fetching otherdevices_svalues by index? Topic is solved
Lomax
Post by Lomax »
I'm quite new to the Domoticz Lua API - how can I read the svalue of a device by index rather than name? All the examples I've seen use the device/sensor name, e.g. otherdevices_svalues["My Sensor"]. I don't like this at all since the name is liable to change, and would prefer to use the device index instead, e.g. otherdevices_svalues[73] - but I think this returns nil even though the index is valid.
Lomax
Re: Fetching otherdevices_svalues by index?
Post by Lomax »
*bump*
Lomax
Post by Lomax »
*bump*
Egregius
Domoticz version: v2024.7
Post by Egregius »
I believe your idx will faster change than your name. Think about a complete reinstallation. You can't control idx, but you can choose the name.
jvdz
Domoticz version: 4.107
Post by jvdz »
This code is untested, but something like this should work:
-- get the devicename for idx
function get_devname4idx(devIDX)
	for i, v in pairs(otherdevices_idx) do
		if v == devIDX then
			return i
	return ""
function get_svalue_by_idx(devIDX)
	devname = get_devname4idx(devIDX)
	if devname ~= "" then
		return otherdevices_svalues[devname]
		return nil
get_svalue_by_idx(123)
Jos
Lomax
Post by Lomax »
Thanks guys, I think @Egregius has a good point, and though @jvdz's code is a reasonable work-around it doesn't use the index to directly select the sensor, which is what I was hoping for. At some point it might be worth updating otherdevices_svalues to allow integer as well as string indexing.
