How to avoid Time script to overlap
Posted: Monday 30 January 2017 9:14
by emme
Ciao,
I have few time script that runs for more than 1 minute (they ping some devices and retry if they are not availble... so it could take time)
Because it is supposed to trigger switches in Domoticz, I have the issue that the script runs twice because a minute pass and it strats while the old one is still running.
This results in double actions... I don't like it!
So, unless there is no a clear way to avoid a script to run in case it has not finished yet, I create a not-so-complex workaround I'm going to show you:
Example:
script_time_dostuff.lua
   os.execute('sleep 65')
..so this would overlap in the next minute
SOLUTION:
CREATE:
string variable called dostuff_running (0-not running, 1-running)
script_time_dostuff_running.lua
   os.execute('sleep 2') --this to ensure the other script starts
   if uservariables['dostuff_running'] == '0' then commandArray['Variable:dostuff_running'] = '1'
EDIT script_time_dostuff.lua as follow:
   commandArray['Variable:dostuff_running'] = '0'
of course... the script could run once every 2 minutes in the worst case, but if it takes less that 60secs, it will run correctly the next minute
ciao
M
Re: How to avoid Time script to overlap
Posted: Monday 30 January 2017 20:05
by jvdz
In genreral my comment would be NOT to do this with the TIME event, but rather run the script with CRON which will update the switch status by means of a JSON call.
Jos
