How to avoid Time script to overlap
emme
Domoticz version: latest
Post by emme »
Ciao,
I have few time script that runs for more than 1 minute (they ping some devices and retry if they are not availble... so it could take time)
Because it is supposed to trigger switches in Domoticz, I have the issue that the script runs twice because a minute pass and it strats while the old one is still running.
This results in double actions... I don't like it!
So, unless there is no a clear way to avoid a script to run in case it has not finished yet, I create a not-so-complex workaround I'm going to show you:
Example:
script_time_dostuff.lua
   os.execute('sleep 65')
..so this would overlap in the next minute
SOLUTION:
CREATE:
string variable called dostuff_running (0-not running, 1-running)
script_time_dostuff_running.lua
   os.execute('sleep 2') --this to ensure the other script starts
   if uservariables['dostuff_running'] == '0' then commandArray['Variable:dostuff_running'] = '1'
EDIT script_time_dostuff.lua as follow:
   commandArray['Variable:dostuff_running'] = '0'
of course... the script could run once every 2 minutes in the worst case, but if it takes less that 60secs, it will run correctly the next minute
ciao
M
"We always done this way"
jvdz
Domoticz version: 4.107
Re: How to avoid Time script to overlap
Post by jvdz »
In genreral my comment would be NOT to do this with the TIME event, but rather run the script with CRON which will update the switch status by means of a JSON call.
Jos
