changing security via LUA
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
I want to change the globalvariable security to "Arm away" in a lua script. But it seems not to work. Perhaps it is impossible, or I don't know the correct syntax. Can anybody help me?
commandArray['Security']='Arm Away'
commandArray['globalvariables:Security']='Arm Away'
What is correct? Thanks
jvdz
Domoticz version: 4.107
Re: changing security via LUA
Post by jvdz »
This should work fine:
commandArray['SecPanel']='Arm Home'
commandArray['SecPanel']='Arm Away'
commandArray['SecPanel']='Disarm'
Jos
harrykausl
Hello Jos,
thanks for the reply. I include it in my script (it is a device-based-lua script) but it seems not to work.
if (devicechanged['Sicherheit'] == 'On') then
print ( globalvariables['Security'] )
For the print statmements I see the following in the log:
2017-01-28 13:29:48.042 User: Admin initiated a switch command (94/Sicherheit/On)
2017-01-28 13:29:48.050 LUA: Disarmed
So security hasn't changed. I also see it, because I have a security script which doesn't start. When I change security status via the security panel the script starts.
harrykausl
I could fix it myself. I had to set a password for the security panel, arm it and then I saw it as a switch. Then it worked.
jvdz
Post by jvdz »
That is because it isn't change at the time you fill the TAble, but rather processed after the LUA script ends.
Look at the domoticz.log to see if the security setting changed after the script completed.
You could also create a LUA script called: script_security_panel-changes.lua and add this into it:
printlog('###', 'SecPanel: status changed to ' .. globalvariables['Security'])
Jos
jvdz
Post by jvdz »
harrykausl wrote:I could fix it myself. I had to set a password for the security panel, arm it and then I saw it as a switch. Then it worked.
I see I was answering while you posted this.
Good to hear it worked now!
Jos
harrykausl
@Jos: Thanks!
