internal temperature from other raspberry pi's
dakipro
Domoticz version: 3.5877
Post by dakipro »
From time to time my Kodi gets a bit hot, so I wanted to see and log its temperature in domoticz. I can see the temperature by typing /opt/vc/bin/vcgencmd measure_temp in the console, but wanted to send it to domoticz. And I found small script on google that I changed a bit, and have cron send value to virtual temperature sensor every few minutes. Script is very simple and looks like
#!/usr/bin/python
import subprocess
import time
import os
import urllib2
serverIP = "192.168.1.1:8080"
deviceId = 1
currentTemp = subprocess.check_output(["/opt/vc/bin/vcgencmd","measure_temp"])
currentTemp = float(currentTemp.split("=")[1][:-3])
urllib2.urlopen("http://" + serverIP + "/json.htm?type=command&param=udevice&idx=" + str(deviceId) + "&nvalue=0&svalue=" + str(currentTemp))
Beginners guide and cron setup (that I wish I had found :) ) is here
http://www.domoticz.com/forum/viewtopic ... 02#p116402
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
AYAMY
Re: internal temperature from other raspberry pi's
Post by AYAMY »
this is extacly what i'm looking for.... THX
zodracom
Domoticz version: V4.7900
Post by zodracom »
so, de device ID is your IDX to the virtual sensor?
Jasper79
Post by Jasper79 »
Thanks,
I tried using this though when entering
python3 temperaturefordomoticz.py
it returns
  File "temperaturefordomoticz.py", line 5, in <module>
    import urllib2
ModuleNotFoundError: No module named 'urllib2'
Edit: data does start to come through now.
FireWizard
Post by FireWizard »
@Jasper79
You run this script as a Python3 script but it is a Python2 script.
Try:
python temperaturefordomoticz.py
Jasper79
Post by Jasper79 »
Thanks, that didn't end up with a error.
