Hi All,
I have running a S0 meter over tcp to collected the kwh from my solar panel inverters.
Sometimes there are wrong values insert in the database, so i it would be nice if a format check is possible to prevent that wrong values can be insert in the database. I know that it is possible to edit the values in de DB but it would be better if it is possible to prevent.
Is there a way to build a format checker?
The values that are send from the S0 meters will look like this:
Thank you!
S0 meter with format check to prevent wrong values
Misterik
Re: S0 meter with format check to prevent wrong values
perhaps with a database trigger (before insert)https://www.tutorialspoint.com/sqlite/s ... iggers.htm
RPI-3 : RFLink + Zigbee2MQTT + Shelly + MySensors + Milight
