ZWave association + slow response
Posted: Saturday 21 January 2017 17:07
I've just started out with zwave, and I a running into 2 problems. I hope someone can help.
My setup is a RPi 3 with RazBerry board. And currently only Fibaro Dimmer 2 modules.
First problem:
I want to use a S2 button of one dimmer to turn on another dimmer. To achieve this I've put the second dimmer (node 15) in group 4 and 5 of the first one (node 13). But pressing the s2 button does not turn on the other light.
I've attached a screenshot of the groups. Is this not correct?
Second problem:
Sometimes switching of lights through the web interface takes more than 10 seconds. The OZW_LOG contains a lot of these messages:
First problem:
Second problem:
2017-01-21 15:50:59.623 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-01-21 15:50:59.623 Always,
2017-01-21 15:50:59.623 Always, Dumping queued log messages
2017-01-21 15:50:59.624 Always, End of queued log message dump
2017-01-21 15:51:02.197 Error, Node012, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2017-01-21 15:51:02.197 Always,
2017-01-21 15:51:02.198 Always, Dumping queued log messages
2017-01-21 15:51:02.198 Always, End of queued log message dump
2017-01-21 15:51:02.199 Always,
2017-01-21 15:51:02.343 Error, Node012, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2017-01-21 15:51:02.343 Always,
2017-01-21 15:51:02.344 Always, Dumping queued log messages
2017-01-21 15:51:02.345 Always,
2017-01-21 15:51:02.345 Always, End of queued log message dump
''2017-01-21 15:51:04.559 Error, Node008, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2017-01-21 15:51:04.559 Always,
2017-01-21 15:51:04.560 Always, Dumping queued log messages
2017-01-21 15:51:04.560 Always, End of queued log message dump
2017-01-21 15:51:04.561 Always,
