Advanced network monitoring
Posted: Thursday 19 January 2017 11:47
by franzelare
I have combined a few scripts in Domoticz to monitor my network performance that I like to share.
This is the floorplan with all my network vitals displayed in one quick overview
Checking if network devices are online
I have multiple scripts runing, first the ARP scan to detect if devices are on or off, this way you don't have to know the IP of the devices in your network and can use a DHCP server.
This script is based on this topic on domoticz forum: viewtopic.php?f=23&t=5256
I have 3 user variable strings with the mac addresses and device ID's with it.
The Lua time script runing in domoticz
For my mysensor units I have a watchdog script runing, that sends an on switch command to every mysensor unit (ESP units over WiFi and NRF24 units over the mysensor network mesh) every unit responds by toggeling the switch off again so I know the unit is still alive. For the ESP units I have a timeout of 1 minute in the hardware configuration in domoticz, so it will try to re-connect if there is no response to the heartbeat ChildID and on the mysensor nodes I have one output pin to pull the reset to ground in case no heartbeat ID is received for 5 minutes. with this watchdog script I assume a node to be dead when I miss 2 heartbeats, so I miss one and cannot connect again within 1 minute, meaning the node has crashed and need to wait until the watchdog timer on the unit runs out and a hard reset is done... (soft resets fail often on the ESP units) I also track failing nodes in a log file on the server.
for details see my post in this topic on the hardware and code: viewtopic.php?f=42&t=9775
Secondly I run a Ping script for the main devices in my network that have a fixed IP, like ESP units that run as Mysensor nodes and my switches and network drives.
This is derrived from the arp scan script and this topic on the domoticz forum: viewtopic.php?f=38&t=13421
This is the time based lua script runing in domoticz
For some devices I also want to know the uptime, since I'm suffering from devices in my network loosing communication, so I track the time decives are on with a custom counter and a lua script runing from domoticz.
This script is based on this forum topic: viewtopic.php?f=38&t=11985
Last I want to monitor ontime for some devices, just to see how often the phones, TV and so on is switched on... just because I can...
For the domoticz servers I use them to do a crosscheck if domoticz is still runing and if not reboot the server, since just restarting domoticz is not always working. I do this with a time based lua script on both servers
The script switches a virtual switch to let me know it rebooted the other server, in the startup script of the other server it sends an off command again so I can see in the logging that the reboot was successful
- floorplan.jpg (206.32 KiB) Viewed 5227 times
- Spoiler: show
-- source https://www.domoticz.com/forum/viewtopic.php?f=23&t=5256 PRINT_MODE = false -- when true wil print output to log and send notifications function splitString(str, delim, maxNb) -- Eliminate bad cases... if string.find(str, delim) == nil then return { str } end if maxNb == nil or maxNb < 1 then maxNb = 0 -- No limit end local result = {} local pat = "(.-)" .. delim .. "()" local nb = 0 local lastPos for part, pos in string.gmatch(str, pat) do nb = nb + 1 result[nb] = part lastPos = pos if nb == maxNb then break end end -- Handle the last field if nb ~= maxNb then result[nb + 1] = string.sub(str, lastPos) end return result end function CheckMac(maclist) Lines=splitString(maclist,"|") for i,line in pairs(Lines) do macs=splitString(line,";") if PRINT_MODE == true then print ("MAC Address to Poll: "..macs[1].." On IDX:"..macs[2]) end execcommand="sudo /home/pi/domoticz/scripts/bash/Check_MAC.sh "..macs[1].." "..macs[2].." &" os.execute(execcommand) end end commandArray = {} if PRINT_MODE == true then print ("Checking presence list 1") end list1= uservariables['PRESENCE_LIST1'] CheckMac(list1) if PRINT_MODE == true then print ("Checking presence list 2") end list2= uservariables['PRESENCE_LIST2'] CheckMac(list2) if PRINT_MODE == true then print ("Checking presence list 3") end list3= uservariables['PRESENCE_LIST3'] CheckMac(list3)
- Spoiler: show
#!/bin/bash MAC=$1 IDX=$2 sudo arp-scan --localnet | grep -e $MAC if [ $? -eq 1 ] then echo "Device $MAC Not in LOCAL LAN" curl "http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=$IDX&switchcmd=Off" else echo "Device $MAC in LOCAL LAN" curl "http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=$IDX&switchcmd=On" fi
- Spoiler: show
commandArray = {} PRINT_MODE = false -- when true wil print output to log and send notifications function timedifference (s) year = string.sub(s, 1, 4) month = string.sub(s, 6, 7) day = string.sub(s, 9, 10) hour = string.sub(s, 12, 13) minutes = string.sub(s, 15, 16) seconds = string.sub(s, 18, 19) t1 = os.time() t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds} difference = os.difftime (t1, t2) return difference end LastupdateESPstalletje = otherdevices_lastupdate['HeartbeatESPStalletje'] ESPStaldifference=timedifference (LastupdateESPstalletje) if PRINT_MODE == true then print('Lastupdate ESP stalletje ' .. LastupdateESPstalletje) print('Time difference ' .. ESPStaldifference) end if (ESPStaldifference>=130 and otherdevices['ESPStalletjeAlive'] == 'On')then commandArray['ESPStalletjeAlive'] = 'Off' if PRINT_MODE == true then print('Lost connection with ESP Stalletje') end CurrentTime=os.date("%Y-%m-%d %H:%M:%S") file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a") io.output(file) io.write(CurrentTime.. " Mysensor ESP stalletje connection lost" .. "\n") io.close(file) if PRINT_MODE == true then print('Writing to error log') end end if (ESPStaldifference<=130 and otherdevices['ESPStalletjeAlive'] == 'Off')then if PRINT_MODE == true then print('ESP stalletje is a live again') end commandArray['ESPStalletjeAlive'] = 'On' CurrentTime=os.date("%Y-%m-%d %H:%M:%S") file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a") io.output(file) io.write(CurrentTime.. " Mysensor ESP stalletje connection operational again" .. "\n") io.close(file) if PRINT_MODE == true then print('Writing to error log') end end LastupdateESPIR = otherdevices_lastupdate['HeartbeatESPIRRemote'] ESPIRdifference=timedifference (LastupdateESPIR) if PRINT_MODE == true then print('Lastupdate ESP IR Remote ' .. LastupdateESPIR) print('Time difference ' .. ESPIRdifference) end if (ESPIRdifference>=130 and otherdevices['ESPIRAlive'] == 'On') then commandArray['ESPIRAlive'] = 'Off' if PRINT_MODE == true then print('Lost connection with ESP IR Remote') end CurrentTime=os.date("%Y-%m-%d %H:%M:%S") file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a") io.output(file) io.write(CurrentTime.. " Mysensor ESP IR Remote connection lost" .. "\n") io.close(file) if PRINT_MODE == true then print('Writing to error log') end end if (ESPIRdifference<=130 and otherdevices['ESPIRAlive'] == 'Off')then if PRINT_MODE == true then print('ESP IR Remote is a live again') end commandArray['ESPIRAlive'] = 'On' CurrentTime=os.date("%Y-%m-%d %H:%M:%S") file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a") io.output(file) io.write(CurrentTime.. " Mysensor ESP IR Remote connection operational again" .. "\n") io.close(file) if PRINT_MODE == true then print('Writing to error log') end end LastupdateESPGSR = otherdevices_lastupdate['GSRHEARTBEAT'] ESPGSRdifference=timedifference (LastupdateESPGSR) if PRINT_MODE == true then print('Lastupdate ESP GSR ' .. LastupdateESPGSR) print('Time difference ' .. ESPGSRdifference) end if (ESPGSRdifference>=130 and otherdevices['ESPGSRAlive'] == 'On') then commandArray['ESPGSRAlive'] = 'Off' if PRINT_MODE == true then print('Lost connection with ESP GSR') end CurrentTime=os.date("%Y-%m-%d %H:%M:%S") file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a") io.output(file) io.write(CurrentTime.. " Mysensor ESP GSR connection lost" .. "\n") io.close(file) if PRINT_MODE == true then print('Writing to error log') end end if (ESPGSRdifference<=130 and otherdevices['ESPGSRAlive'] == 'Off')then if PRINT_MODE == true then print('ESP GSR is a live again') end commandArray['ESPGSRAlive'] = 'On' CurrentTime=os.date("%Y-%m-%d %H:%M:%S") file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a") io.output(file) io.write(CurrentTime.. " Mysensor ESP GSR connection operational again" .. "\n") io.close(file) if PRINT_MODE == true then print('Writing to error log') end end -- send watchdog signals to mysensor gateway's commandArray['HeartBeatBedLight'] = 'On' commandArray['HeartbeatESPStalletje'] = 'On' commandArray['HeartbeatArduinoVoordeur'] = 'On' commandArray['GSRHEARTBEAT'] = 'On' commandArray['GSLHEARTBEAT'] = 'On' commandArray['GWRHEARTBEAT'] = 'On' commandArray['GWLHEARTBEAT'] = 'On' commandArray['HeartbeatESPIRRemote'] = 'On' -- commandArray['HeartbeatESPVerwarming'] = 'On' -- commandArray['HeartbeatESPRGB'] = 'On' return commandArray
- Spoiler: show
PRINT_MODE = false -- when true wil print output to log and send notifications function splitString(str, delim, maxNb) -- Eliminate bad cases... if string.find(str, delim) == nil then return { str } end if maxNb == nil or maxNb < 1 then maxNb = 0 -- No limit end local result = {} local pat = "(.-)" .. delim .. "()" local nb = 0 local lastPos for part, pos in string.gmatch(str, pat) do nb = nb + 1 result[nb] = part lastPos = pos if nb == maxNb then break end end -- Handle the last field if nb ~= maxNb then result[nb + 1] = string.sub(str, lastPos) end return result end function CheckIP(IPlist) Lines=splitString(IPlist,"|") for i,line in pairs(Lines) do IP=splitString(line,";") if PRINT_MODE == true then print ("Check if device is on to ping : "..IP[2]) end pingdevice = tostring(IP[2]) if otherdevices [pingdevice] == 'On' then if PRINT_MODE == true then print ("Device " ..IP[2].. " is on") print ("IP Address to Poll: "..IP[1].." With 3 counts for IDX "..IP[3]) end execcommand="sudo /home/pi/domoticz/scripts/bash/ping.sh " ..IP[1].." 3 "..IP[3].." &" os.execute(execcommand) else if PRINT_MODE == true then print ("Device " ..IP[2].. " is off") end end end end commandArray = {} if PRINT_MODE == true then print ("Checking ping list 1") end list1= uservariables['PING_LIST1'] CheckIP(list1) if PRINT_MODE == true then print ("Checking ping list 2") end list2= uservariables['PING_LIST2'] CheckIP(list2) if PRINT_MODE == true then print ("Checking ping list 3") end list3= uservariables['PING_LIST3'] CheckIP(list3)
- Spoiler: show
host=$1 count=$2 idx=$3 name=$4 domoticz=127.0.0.1 multiply=1000 value=`ping -c $count $host | awk -F '/' 'END {print $5}'` value2=$(echo "$value*$multiply" | bc) value3=${value2%.*} echo "$4 $value3" curl "$domoticz:8080/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$value3"
- Spoiler: show
-- this script is to detect Uptime of devices in domoticz -- based on the script of mvzut that can be found here on the forum -- https://www.domoticz.com/forum/viewtopic.php?f=38&t=11985 -- this has to be a time based lua script in domoticz (as device script this will not work) -- for every device to monitor a counter has to be created as virtual devicecount -- Create an custom counter using the Dummy hardware component (first add this component if you haven't already done so before, using Setup>Hardware). -- Then go to the Utility section, change the type of your new counter from Energy to Counter, and fill in the Value Quantity (e.g. "On time") and Value Units ("Minutes"). -- Check the Device ID (idx) that is given to the new counter device. -- this script can be run in combination with an ping, bluetooth scan or an arp scan what is in some cases more reliable -- ping: https://www.domoticz.com/wiki/Presence_detection -- bluetooth: https://www.domoticz.com/wiki/Presence_detection_(Bluetooth_4.0_Low_energy_Beacon) -- arp scan: https://www.domoticz.com/forum/viewtopic.php?f=23&t=5256 -- define general script values devicecount = 8 -- number of deviced to be cheked by the script for on time PRINT_MODE = false -- when true wil print output to log and send notifications -- create a table to store device information devicetable = {} -- Device 1 device = 1 devicetable["name" .. device] = 'KPN Modem' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime KPN Modem' -- exact name of the counter created for this device devicetable["ID" .. device] = 368 -- idx of the counter created for this device -- Device 2 device=2 devicetable["name" .. device] = 'Pi2Heating' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime Pi2Heating' -- exact name of the counter created for this device devicetable["ID" .. device] = 369 -- idx of the counter created for this device -- Device 3 device=3 devicetable["name" .. device] = 'ESPIRAlive' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime IR remote' -- exact name of the counter created for this device devicetable["ID" .. device] = 370 -- idx of the counter created for this device -- Device 4 device=4 devicetable["name" .. device] = 'ESPStalletjeAlive' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime Schuur' -- exact name of the counter created for this device devicetable["ID" .. device] = 371 -- idx of the counter created for this device -- Device 5 device=5 devicetable["name" .. device] = 'ESPGSRAlive' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime ESP GSR' -- exact name of the counter created for this device devicetable["ID" .. device] = 372 -- idx of the counter created for this device -- Device 6 device=6 devicetable["name" .. device] = 'ESPGSLAlive' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime ESP GSL' -- exact name of the counter created for this device devicetable["ID" .. device] = 373 -- idx of the counter created for this device -- Device 7 device=7 devicetable["name" .. device] = 'ESPGWRAlive' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime ESP GWR' -- exact name of the counter created for this device devicetable["ID" .. device] = 374 -- idx of the counter created for this device -- Device 8 device=8 devicetable["name" .. device] = 'ESPGWLAlive' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'Uptime ESP GWR' -- exact name of the counter created for this device devicetable["ID" .. device] = 375 -- idx of the counter created for this device commandArray = {} for i=1,devicecount do if otherdevices[devicetable["name" .. i]] == 'On' then TotalMinutesUp = tonumber(otherdevices_svalues[devicetable["timer" .. i]]) TotalMinutesUpNew = TotalMinutesUp + 1 TimerID = tonumber(devicetable["ID" .. i]) execcommandUp="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..TotalMinutesUpNew.." &" os.execute(execcommandUp) if PRINT_MODE == true then print('Device sequence: ' .. i) print('Device name detected On :' .. devicetable["name" .. i]) print('Device name On timer :' .. devicetable["timer" .. i]) print('Device ID timer counter :' .. TimerID) print('Previous Uptime: ' .. TotalMinutesOn) print('New Uptime: ' .. TotalMinutesOnNew) end elseif otherdevices[devicetable["name" .. i]] == 'Off' then if PRINT_MODE == true then print('Device sequence: ' .. i) print('Device detected Off: ' .. devicetable["name" .. i]) print('Resetting uptimer to 0') Reset=0 execcommandUp="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..Reset.." &" os.execute(execcommandUp) end else if PRINT_MODE == true then print('Device sequence: ' .. i) print('Device ERROR: ' .. devicetable["name" .. i]) end end end return commandArray
- Spoiler: show
#!/bin/bash IDX=$1 COUNT=$2 curl "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=$IDX&nvalue=0&svalue=$COUNT"
- Spoiler: show
-- this script is to detect on time of devices in domoticz -- based on the script of mvzut that can be found here on the forum -- https://www.domoticz.com/forum/viewtopic.php?f=38 -- this has to be a time based lua script in domoticz (as device script this will not work -- for every device to monitor a counter has to be created as virtual devicecount -- Create an incremental counter using the Dummy hardware component (first add this component if you haven't already done so before, using Setup>Hardware). -- Then go to the Utility section, change the type of your new counter from Energy to Counter, and fill in the Value Quantity (e.g. "On time") and Value Units ("Minutes"). -- Check the Device ID (idx) that is given to the new counter device. -- this script can be run in combination with an ping, bluetooth scan or an arp scan what is in some cases more reliable -- ping: https://www.domoticz.com/wiki/Presence_detection -- bluetooth: https://www.domoticz.com/wiki/Presence_detection_(Bluetooth_4.0_Low_energy_Beacon) -- arp scan: https://www.domoticz.com/forum/viewtopic.php?f=23&t=5256 -- define general script values devicecount = 11 -- number of deviced to be cheked by the script for on time PRINT_MODE = false -- when true wil print output to log and send notifications -- create a table to store device information devicetable = {} -- Device 1 device = 1 devicetable["name" .. device] = 'FransMobiel' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'FransMobielTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 237 -- idx of the counter created for this device -- Device 2 device=2 devicetable["name" .. device] = 'SusanMobiel' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'SusanMobielTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 238 -- idx of the counter created for this device -- Device 3 device=3 devicetable["name" .. device] = 'FransTablet' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'FransTabletTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 239 -- idx of the counter created for this device -- Device 4 device=4 devicetable["name" .. device] = 'SusanTablet' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'SusanTabletTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 240 -- idx of the counter created for this device -- Device 5 device=5 devicetable["name" .. device] = 'FransPC' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'FransPCTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 241 -- idx of the counter created for this device -- Device 6 device=6 devicetable["name" .. device] = 'SusanPC' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'SusanPCTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 242 -- idx of the counter created for this device -- Device 7 device=7 devicetable["name" .. device] = 'SonyBlueRay' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'SonyBlueRayTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 243 -- idx of the counter created for this device -- Device 8 device=8 devicetable["name" .. device] = 'ITV receiver' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'ITV receiverTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 244 -- idx of the counter created for this device -- Device 9 device=9 devicetable["name" .. device] = 'ASM-Lan' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'ASM-LanTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 245 -- idx of the counter created for this device -- Device 10 device=10 devicetable["name" .. device] = 'ASM-Wifi' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'ASM-WifiTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 246 -- idx of the counter created for this device -- Device 11 device=11 devicetable["name" .. device] = 'Chromecast' -- exact name of the device to be checked for on time devicetable["timer" .. device] = 'ChromecastTimer' -- exact name of the counter created for this device devicetable["ID" .. device] = 247 -- idx of the counter created for this device commandArray = {} for i=1,devicecount do if otherdevices[devicetable["name" .. i]] == 'On' then TotalMinutesOn = tonumber(otherdevices_svalues[devicetable["timer" .. i]]) TotalMinutesOnNew = TotalMinutesOn + 1 TimerID = tonumber(devicetable["ID" .. i]) -- commandArray['UpdateDevice'] = TimerID .. '|0|' .. tonumber(TotalMinutesOnNew) execcommandOn="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..TotalMinutesOnNew.." &" os.execute(execcommandOn) if PRINT_MODE == true then print('Device sequence: ' .. i) print('Device name detected On :' .. devicetable["name" .. i]) print('Device name On timer :' .. devicetable["timer" .. i]) print('Device ID timer counter :' .. TimerID) print('Previous on time: ' .. TotalMinutesOn) print('New on time: ' .. TotalMinutesOnNew) end elseif otherdevices[devicetable["name" .. i]] == 'Off' then if PRINT_MODE == true then print('Device sequence: ' .. i) print('Device detected Off: ' .. devicetable["name" .. i]) print('No update of the timer needed') end else if PRINT_MODE == true then print('Device sequence: ' .. i) print('Device ERROR: ' .. devicetable["name" .. i]) end end end return commandArray
- Spoiler: show
PRINT_MODE = false -- when true wil print output to log and send notifications commandArray = {} if PRINT_MODE == true then print ("Checking if heating Pi 2 is online") end execcommand="sudo /home/pi/domoticz/scripts/bash/CheckOnline.sh" os.execute(execcommand) return commandArray
- Spoiler: show
#!/bin/sh # check domoticz status=`curl -s -i -H "Accept: application/json" "http://192.168.2.141:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'` if [ $status ] then echo "Domoticz draait nog" else echo "Domoticz draait niet meer, rebooting server" curl "http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=146&switchcmd=On" sshpass -p 'xxxxxxxx' ssh [email protected] 'sudo reboot' fi
