Hi there,
My Devolo Room Control Device is, all of the sudden, sending wrong temperatures. The Display says 18 but in Domoticz it's 36,5, as an example. The temperature literally jumped from 20 to almost 40 deg, while the Display value on the Device itself still displaying 20.. This happened in the night somewhat around 1:30. The Devolo Radiator sensors are working fine.
As I'm a totally rookie, I need some advice what to do now.☺
Running Domoticz latest beta (upgraded some hours before that happened) on a Raspberry Pi with Gen5 Z-Stick.
Thanx in advance!
devolo Room Control sending wrong temp values
Olfer
Domoticz on RPi3 with Aeontec Z-Stick gen5. Beta.
Z-Wave, Zigbee, WiFi and MQTT (mainly Tasmota), Neo Cool Cam, Devolo, Fibaro, Shelly, Hue, Osram, Blitzwolf, TP-Link, Alexa. Latest: Somfy IO integration
Olfer
Re: devolo Room Control sending wrong temp values
Might be a Problem... Now one of the radiator controllers dropped down to 9 degree and has not been seen again in domoticz since then ...strange.
Wife is not amused ...
