Reading of ZMF120ACd meters in Sweden
joostvanderlinde
Domoticz version: 2023.2
Post by joostvanderlinde »
Since I have a house in Sweden as well, I have fiddled a bit to readout the smart meter my gridcompany (Ellevio / Fortum) installed years ago.
It should be possible to read this meter (the ZMF120ACd) via the optical interface (IEC1107 protocol), but I until now I did not succeed in that. I suspect my Gridcompany disabled the IR communication capabilities of the meter.
Please post if you were able to readout the meter using IEC1107 (or similar), because using IEC1107 to readout meters is prefered to most other methods.
I did succeed to collect the IR pulses the meter transmits via what is supposed to be the optical interface. The meter transmits one IR pulse every WatHour. The module I build holds to to meter using a strong magnet. The meter itself is in no way impacted.
My module generates similar telegrams as the S0PCM modules (sold by smartmeterdashboard.nl) over USB/serial that are supported by Domoticz. So: Now I am able to keep track of the energyconsumption my gridmeter registered (unfortunately not the momentary power) in Domoticz.
If you are interested in using this IRPCM (InfraRed Pulse Counter Module), please let me know.
Disclaimer: smartmeterdashboard.nl is my site, this message is not meant to be an advertisement. Please let me know if I am violating any forum rules.
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
nollbit
Re: Reading of ZMF120ACd meters in Sweden
Post by nollbit »
I'd love to hear more about this! I'm looking to buy or build a similar counter.
connectix
Post by connectix »
You can use this gateway for connecting Swedish Smart meters:
https://www.connectix.nl/swedish-smart- ... omey-mqtt/
You can use basic telnet, mqtt or the api on the internal webserver.
It works with Home Assistant, Domoticz, Homey and DSMR-Reader. You can even use mqtt and use your own grafana dashboard with influxdb and node-red
