dual switches visible as single switch and not working fine
Posted: Sunday 15 January 2017 10:11
by edwin01
I have installed Domoticz on my Synology NAS with jadahl.com. I have two devices:
1x TZ36D, Z-WAVE Dual Wall Switch.
1x Philiotech PAN04 dual relay module.
Both devices are visible as switch with just one switch/releay. Also, when i click the relay switch sometimes it switches both relay on/off but mostly the device goes into failure.
Am I doing something wrong or are the devices not supported with Domoticz? Hope someone can help.
Thanks.
Edwin
Re: dual switches visible as single switch and not working fine
Posted: Sunday 15 January 2017 10:26
by gizmocuz
for the philio (maybe the other 2) you should see 3 switches in the devices table, one of the switches is an 'All' on/off
Posted: Sunday 15 January 2017 10:32
by edwin01
Hi. I would expect that indeed. But there is only one switch visible.
Posted: Sunday 15 January 2017 10:45
by Domosapiens
Make sure you check for the PAN04 that you have 3 connections with the Z-Wave controller:
Go to Setup -> Hardware -> Blue Setup button from your controller -> Node Management -> Groeps & Network:
Add 1 (=controller) to group 1 and group 2 and group 3.
TZ36ZD I don't know, could a similar connection problem (read the TZ36ZD manual)
But I don't see a TZ36ZD.xml file in the Config/wenzhou directory.
So OpenZwave support is doubtful. It needs to act as a secondary controller (like a remote control).
If you need help from the community, then make pictures of the current situation (hardware screen, Groeps & Network)
Posted: Sunday 15 January 2017 11:04
by edwin01
Thanks for the help. I have attached the pictures.
Posted: Sunday 15 January 2017 12:48
by Domosapiens
Edwin,
every node should have an ID and Type (pic: nodes.jpg)
At least the Controller and the PAN04.
The TZ36ZD is recognized as TZ56 and has a .xml file (and should be recognized also)
So something went wrong.
As result of that, you don't see any possibility to connect the controller (in Groups.jpeg)
ID's has to be solved first.
Disable your Z-Wave controller
Remove the cache file: zwfg_0x.......xml in the Config directory
Enable your Z-Wave controller.
Check if you get the correct ID's (can be found in the manufacturer_specific.xml)
Success
