Uk Light wall switch
SHadley1138
Post by SHadley1138 »
Can anyone recommend a U.K. Wall mounted Light switch that will work with Rflink
I really want something that I can manually switch or automate
Any help would be appreciated
Steve
sach
Re: Uk Light wall switch
Post by sach »
lightwaverf works great with Domoticz and RFlink.
I have been using it for a good few years now.
SHadley1138
With no extra bridge boxes? I've not tried lightwave, as I was uncertain if I could just buy a switch on its own
Swifty
Post by Swifty »
Same question here.. £30+ per light switch puts me off lightwaverf, are there any cheaper alternatives?
I have looked at the Energenie switches (can be had for £16 at screwfix) but they don't publish status changes, so things can get out of sync when it's switched physically.
sach
Post by sach »
LightwaveRf doesn't publish status changes either. I don't know of any RFlink devices that do TBH.
No need for the hub if using RFlink
SHadley1138
Swifty wrote:Same question here.. £30+ per light switch puts me off lightwaverf, are there any cheaper alternatives?
Do they work ok with RFlink?
Swifty
Post by Swifty »
Ah that's interesting, I always thought that LightwaveRF devices sent a signal when physically used (don't ask me why i thought that!)
@SHadley1138, yes I'm using the Energenie sockets with RFLink, and have two of the light switches.
The work fine with RFLink as far as I'm aware, but my wall switches are not fitted yet - my back boxes are not deep enough..
blackdog65
Post by blackdog65 »
Hiya,
I use LWRF extensively in my house. The whole ground floor, apart from sitting room lights, outside floodlights and half the upstairs. I use a combination of wired and wireless switches, sockets and relays.
So to clarify:
The wired switches, sockets and relays ONLY receive a signal... i.e. from door sensor, pir, RfxTrx, remote etc
The wireless switches ONLY send a signal... pretty much a switch shaped wall mounted remote.
So far, I've got on really well with them and only use them where and when I can see the rare occasion when a signal has been missed. For critical/out of sight stuff (Kids bedroom lights grrrr) you need to go z-wave as they report back their status.
As for reliability... I've had one remote socket fail... that's it in over 3 years.
Hope this helps
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
blackdog65 wrote:Hiya,
Hello Sean,
I started recently using LWRF for the wall sockets, they are nice.
How have you solved the default status to OFF after a power outage? If I understand the in wall double sockets will go OFF on power-up.
Also, do you miss at all not being able to know the status of these?
Eddie
11101101 - www.machinon.com
