Maybe I'm just tired. Today I install a GE zw3002 & zw2001 and it/they work - push the button and lightsOn/lightsOff. Also installed a GE 12722 and it works OK also. I had expected to be able to turn them on/off and have Domoticz pick them up and register under Devices. Nope. Restart Domoticz - nope. Twisty little passages all alike.....
What am I doing wrong?
Next day. I backed up my domoticz subdir (just in case) did a 'rm -rf' and then a full (re)install. Webbed in and added my OpenZWave USB then checked for Devices -
and 2 plugs and 1 switch. My 2 new switches - not there.
Is there a curl http://sg53:8080/json.htm?type... query-net?? find-all-devices???
ZWave switch(s) not being detected
Re: ZWave switch(s) not being detected (SOLVED)
There is a SciFi short story about Slow Glass. My story is Slow Memory (mine). My Aeon "S2" stick requires I go walk about with it, be within, say 6", of the device and press the button on the stick - (flash... flash... flash...) then turn the light on. The circle on the stick comes on, flashes then back to (flash... flash...). Then walk to the next device and repeat...
