Switch turns on/off every 15 min.
Posted: Wednesday 11 January 2017 15:38
by nedde
I want the switch to turn of after 15 minutes after it is turend on but it keeps
turning on/off every 15 min instead. What's am I doing wrong? Picture Attached.
Re: Switch turns on/off every 15 min.
Posted: Wednesday 11 January 2017 15:41
by anasazi
Shouldn't you be using "Off AFTER 15" instead of FOR.
Posted: Wednesday 11 January 2017 15:45
by jumbotroll
Try this
If Kaffe = On
Do
Set Kaffe = On For 15 minutes
Posted: Wednesday 11 January 2017 15:52
by emme
I think you cannot do that with blocky....
the script will loop all the time....
try LUA instead:
if devicechanged['Kaffe'] and otherdevices['Kaffe'] == 'On' then
commandArray['Kaffe'] = 'On FOR 900' -- the FOR instance works in secs
Posted: Wednesday 11 January 2017 16:00
by Egregius
Or pass2php:
<?php
if(apcu_fetch('sKaffe')=='On'&&apcu_fetch('tKaffe')<time-900) sw(apcu_fetch('iKaffe'),'Off');
Posted: Wednesday 11 January 2017 17:14
by StanHD
There is an "Off After X Seconds" block (900 seconds)
Re: RE: Re: Switch turns on/off every 15 min.
Posted: Friday 13 January 2017 23:10
by nedde
anasazi wrote:Shouldn't you be using "Off AFTER 15" instead of FOR.
Worked a lot better
thx
Sent from my Nexus 6 using Tapatalk
Posted: Tuesday 21 February 2017 11:35
by gielie
I have a question, i have this code.
if devicechanged['Koffie'] and otherdevices['Koffie'] == 'On' then
commandArray['Koffie'] = 'On FOR 600' -- the FOR instance works in secs
if devicechanged['Koffie'] and otherdevices['Koffie'] == 'Off' then
commandArray['SendNotification']='Koffie machine is uitgeschakeld'
But when de koffie is Off Domoticz will spam me with messages, i only want to recieve 1 message after the event took place.
How can i do this?
Posted: Tuesday 21 February 2017 12:27
by Nautilus
gielie wrote:I have a question, i have this code.
How can i do this?
The syntax is bit incorrect, not sure if this is the reason. Try:
if devicechanged['Koffie'] == 'On' then
elseif devicechanged['Koffie'] == 'Off' then
Posted: Tuesday 21 February 2017 12:31
by emme
could it be that the ON FOR 600 keep the device in the devicechanged table for 600 seconds?!
Posted: Tuesday 21 February 2017 12:35
by Nautilus
emme wrote:could it be that the ON FOR 600 keep the device in the devicechanged table for 600 seconds?!
Not sure about this, but agreed that more logical would be:
commandArray['Koffie'] = 'Off AFTER 600'
Posted: Tuesday 21 February 2017 15:47
by gielie
U guys are great, it works, thanks a lot.
Is there also a way to create a countdown?
Posted: Tuesday 21 February 2017 16:03
by Nautilus
gielie wrote:Is there also a way to create a countdown?
Sure, with a time script (they run once each minute) you can at least have a once per minute count down timer...
