Grafana and Virtual Device Stats not working?
thenecroscope
Post by thenecroscope »
I'm new to the forum and also Domoticz. I need a bit of help if possible, I've managed to setup a test dummy device and i've created the following event:
local varidx = 115
if devicechanged['PowerUsage_ZW'] then
varPowerMain = otherdevices_svalues['PowerMain']
varSolarPower = otherdevices_svalues['PowerUsage_ZW']
varPowerDiff = varSolarPower + varPowerMain
print('varPowerMain : '..varPowerMain)
print('varSolarPower : '..varSolarPower)
print('varPowerDiff : '..varPowerDiff)
commandArray['UpdateDevice'] = varidx .. "|0|" .. varPowerDiff
The event is working fine, but for some reason I cannot get it to fire off a HTTP request, which in turn then fires an event to Grafana. No events appear in Grafana or in the influxdb. The HTTP event appears not to be firing for a Virtual Custom Device?
Any suggestions.
Many thanks,
thenecroscope
Re: Grafana and Virtual Device Stats not working?
I've still not managed to get to the bottom of this, any suggetions anyone please.
Many thanks!
Derik
Post by Derik »
do you have this option working?
Users browsing this forum: Bing [Bot], JanJaap and 1 guest
