Hi, After the make connand i get this error :
/home/domoticz/domoticz/hardware/XiaomiGateway.cpp: In member function âvoid XiaomiGateway::xiaomi_udp_server::handle_receive(const boost::system::error_code&, std::size_t)â:
/home/domoticz/domoticz/hardware/XiaomiGateway.cpp:447:27: error: ambiguous overload for âoperator[]â (operand types are âJson::Valueâ and âsize_t {aka long unsigned int}â)
message.append(root2.asString().c_str());
In file included from /home/domoticz/domoticz/hardware/../json/json.h:10:0,
from /home/domoticz/domoticz/hardware/XiaomiGateway.cpp:10:
/home/domoticz/domoticz/hardware/../json/value.h:408:10: note: candidate: Json::Value& Json::Value::operator[](Json::Value::ArrayIndex)
Value& operator[](ArrayIndex index);
/home/domoticz/domoticz/hardware/../json/value.h:416:10: note: candidate: Json::Value& Json::Value::operator[](int)
Value& operator[](int index);
/home/domoticz/domoticz/hardware/../json/value.h:421:16: note: candidate: const Json::Value& Json::Value::operator[](Json::Value::ArrayIndex) const
const Value& operator[](ArrayIndex index) const;
/home/domoticz/domoticz/hardware/../json/value.h:426:16: note: candidate: const Json::Value& Json::Value::operator[](int) const
const Value& operator[](int index) const;
CMakeFiles/domoticz.dir/build.make:3326: recipe for target 'CMakeFiles/domoticz.dir/hardware/XiaomiGateway.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/hardware/XiaomiGateway.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
Anyone knows how to solve this ?
Domoticz compile error
gennapium
- Domoticz version: Stable
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
gennapium
Re: Domoticz compile error
Problem solved,
Thanks Gizmocuz !!
Thanks Gizmocuz !!
How did you solve it ?
