Zwave devices have disappeared
yogui
Post by yogui »
I've switched from a Zway interface to the OpenZWave driver for my razpberry. Since I have several problem and whereas things seemed to be more stable since a few days, I've lost all my hardware this morning.
I've try to restart domoticz and to reboot my RP3 with no results. Into logs, I'm seeing this kind of message :
OpenZWave: Received timeout notification from HomeID xxxxxxxx
Before the problem, both my razberry card and my Zwave sensor were present into the settings menu of the Openzwave device. Now there is nothing
sirray
Re: Zwave devices have disappeared
Post by sirray »
I have exactly the same problem since the end of December (message in log also says: OpenZWave: Received timeout notification from HomeID xxxx ).
I have an RP2 with a Razberry. I tried reinstalling the OS and Domoticz without success. Also putting back a backup didn't solve the problem :-(
yogui
Post by yogui »
After rebooting the RP, now both Razberry and Fibaro device appears into the setting menu... But I've not all the device's feature available. Luminosity is missing whereas other features (movement detection, temperature) are ok.
sirray
Post by sirray »
You only rebooted? As rebooting did not help on my RPi :-( It still cannot see any devices.
yogui
Post by yogui »
I've apply a rpi-update command too to update the kernel and a reboot.
Now I've all my mesures ... We will see how many time they stay alive....
deejc
Domoticz version: 3.5641
Post by deejc »
Every time I reboot my Linux machine my USB changes /dev path and I need to change my zwave stick /dev path maybe this is a similar problem ?
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
lost
Post by lost »
deejc wrote:Every time I reboot my Linux machine my USB changes /dev path and I need to change my zwave stick /dev path maybe this is a similar problem ?
In the wiki, there is a way to set this device path permanent...
