Controller Insists Node is Dead, When it Isn't?...
Posted: Sunday 01 January 2017 11:34
by gcoupe
This is driving me mad. I have a new Fibaro FGS-212 Relay Switch that has been operating normally for a month. In the last few days, it's showing up as a dead node. The Aeotec Zwave stick is reporting that it has received a dead node notification from it.
The annoying thing is that the switch is still working as far as I can see. It can be excluded and included from the network, and when it is freshly included, it will respond to commands sent to it up to the point when the Zstick reports that it's dead. Then, of course, the Zstick refuses to send any commands to it because it claims it is dead - when I'm pretty sure it is not.
2017-01-01 11:02:39.821 OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2017-01-01 11:02:40.006 OpenZWave: Driver Ready
2017-01-01 11:02:40.487 OpenZWave: New Node added. HomeID: 3550212702, NodeID: 27 (0x1b)
2017-01-01 11:03:35.668 OpenZWave: Received Node Dead notification from HomeID: 3550212702, NodeID: 27 (0x1b)
2017-01-01 11:11:21.384 OpenZWave: Closed
2017-01-01 11:16:05.162 OpenZWave: Node Removed. HomeID: 3550212702, NodeID: 27 (0x1b)
2017-01-01 11:16:05.227 OpenZWave: New Node added. HomeID: 3550212702, NodeID: 28 (0x1c)
2017-01-01 11:17:14.786 OpenZWave: Received Node Dead notification from HomeID: 3550212702, NodeID: 28 (0x1c)
017-01-01 11:18:37.199 OpenZWave: Awake Nodes queried
Is this node really dead, or is something else going on? Thanks.
Edit: I found this page about dealing with dead nodes in the OpenZwave knowledge base. I've tried all the steps except resetting the USB controller without success. So it looks as though the nuclear option of resetting the controller and starting all over again to build up the entire network may be necessary. Sigh.
I note this passage in the text, which I find a bit worrisome:
From the OpenZWave side of things, once a Node ends up on the Failed Node List in the controller, the controller will reject any attempt to communicate with it. There may be a command that be issued to the controller to clear the failed node list, or retry communications with failed nodes, but we are not aware of it.
Re: Controller Insists Node is Dead, When it Isn't?...
Posted: Tuesday 03 January 2017 11:43
by gcoupe
This is getting ludicrous. I've now reset the Aeotec USB controller, and rebuilt the network. Now both the new Fibaro FGS-212 relay switches are being reported as dead - and the product ID and type are being reported as 0, so they are also not being recognised in Domoticz. I'm rapidly losing confidence in the system.
Domoticz 59.png (210.56 KiB) Viewed 1248 times
Log status report:
2017-01-03 11:10:17.826 OpenZWave: Starting...
2017-01-03 11:10:17.826 OpenZWave: Version: 1.4.2246.ga583ba8.dirty
2017-01-03 11:10:17.826 OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2017-01-03 11:10:18.123 OpenZWave: Driver Ready
2017-01-03 11:10:18.326 OpenZWave: Value_Added: Unhandled Label: Rain Rate, Unit: mm/h
2017-01-03 11:10:18.560 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 13 (0x0d), Index: 0, Instance: 1
2017-01-03 11:10:18.732 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 15 (0x0f), Index: 0, Instance: 1
2017-01-03 11:10:23.540 Incoming connection from: 192.168.178.45
2017-01-03 11:10:33.392 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 17 (0x11)
2017-01-03 11:10:45.645 Incoming connection from: 192.168.178.21
2017-01-03 11:11:12.434 OpenZWave: Received Node Dead notification from HomeID: 4249877763, NodeID: 16 (0x10)
2017-01-03 11:11:22.444 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 17 (0x11)
2017-01-03 11:11:32.506 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 17 (0x11)
2017-01-03 11:11:47.681 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 11 (0x0b)
2017-01-03 11:11:57.848 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 11 (0x0b)
2017-01-03 11:12:16.543 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 13 (0x0d)
2017-01-03 11:12:27.591 OpenZWave: Received timeout notification from HomeID: 4249877763, NodeID: 15 (0x0f)
2017-01-03 11:12:28.092 OpenZWave: All Nodes queried (Some Dead)
2017-01-03 11:33:03.419 OpenZWave: Heal Network command initiated...
2017-01-03 11:33:58.922 OpenZWave: Received Node Dead notification from HomeID: 4249877763, NodeID: 17 (0x11)
