I included this double relay switch in my system and normal cases work. I have a pushbotton switch (one press light goes on, next goes off). This works for my normal lamp on L1, i have no autoff for L1. On L2 I have the following situation. I have 3 pushbuttons which go to a relais in the wall. I want to add L2 as a 4. pushbutton.. So I have to customize, that for L2 I have a autooff after about one second. But I want to keep L1 on till to the next press. I can configure this, but it seems not work. I have eihter autooff for both or for none. Has anyone any ideas? Thanks!
Fibaro FGS222 Double Relay switch
harrykausl
- Domoticz version: 2021.1
Flopp
- Target OS: -
Re: Fibaro FGS222 Double Relay switch
I also have problem when I turn ON/OFF.
If I turn ON channel 1, it update the time(for last seen) for channel 2
If I turn ON channel 2 and then turn ON channel 1 it will say that channel 2 if OFF and channel 1 is ON. Last seen is updated for both.
I have FGS-223 and they are not depending of each other.
