Help! All nodes dead? Topic is solved
doh
Post by doh »
I woke up this morning to find that my Domoticz system wasn't functioning properly. On investigation, it appears that ALL Z-wave nodes, excluding the Z-Stick S2 controller, are reported as being dead. I've tried rebooting the system and it still shows everything as dead. Doing a network heal doesn't seem to do anything either. Screens attached and log file output below.
Any ideas appreciated as, right now, my whole system appears unusable.
2016-12-28 12:33:25.826 OpenZWave: Starting...
2016-12-28 12:33:25.838 OpenZWave: Version: 1.4-2279-g7c8c27d-dirty
2016-12-28 12:33:25.838 OpenZWave: using config in: /home/pi/domoticz/Config/
2016-12-28 12:33:26.482 OpenZWave: Driver Ready
2016-12-28 12:33:26.509 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.536 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2016-12-28 12:33:26.537 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2016-12-28 12:33:26.545 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Voltage, Instance: 1
2016-12-28 12:33:26.546 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Current, Instance: 1
2016-12-28 12:33:26.547 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power Factor, Instance: 1
2016-12-28 12:33:26.551 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-12-28 12:33:26.553 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-12-28 12:33:26.554 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2016-12-28 12:33:26.554 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2016-12-28 12:33:26.555 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2016-12-28 12:33:26.574 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-12-28 12:33:26.589 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.591 OpenZWave: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2016-12-28 12:33:26.620 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.638 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.643 OpenZWave: Value_Added: Node: 24 (0x18), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.669 OpenZWave: Value_Added: Node: 25 (0x19), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.674 OpenZWave: Value_Added: Node: 26 (0x1a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:26.700 OpenZWave: Value_Added: Node: 27 (0x1b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2016-12-28 12:33:37.020 OpenZWave: Received timeout notification from HomeID: 25485166, NodeID: 4 (0x04)
2016-12-28 12:34:04.152 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 11 (0x0b)
2016-12-28 12:34:14.168 OpenZWave: Received timeout notification from HomeID: 25485166, NodeID: 4 (0x04)
2016-12-28 12:34:35.471 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 10 (0x0a)
2016-12-28 12:34:37.939 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 12 (0x0c)
2016-12-28 12:34:40.451 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 23 (0x17)
2016-12-28 12:34:42.881 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 24 (0x18)
2016-12-28 12:34:45.328 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 25 (0x19)
2016-12-28 12:34:47.891 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 26 (0x1a)
2016-12-28 12:34:50.421 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 27 (0x1b)
2016-12-28 12:35:00.429 OpenZWave: Received timeout notification from HomeID: 25485166, NodeID: 4 (0x04)
2016-12-28 12:35:04.107 OpenZWave: All Nodes queried (Some Dead)
2016-12-28 12:35:04.111 OpenZWave: Received Node Dead notification from HomeID: 25485166, NodeID: 4 (0x04)
2016-12-28 12:35:10.435 OpenZWave: Received timeout notification from HomeID: 25485166, NodeID: 4 (0x04)
Egregius
Domoticz version: v2024.7
Re: Help! All nodes dead?
Post by Egregius »
Have you tried shutdown and power off/on instead of reboot?
doh
Post by doh »
Egregius wrote:Have you tried shutdown and power off/on instead of reboot?
Yes. It made no difference sadly.
Egregius
Post by Egregius »
And the 'has node failed' command in OZWCP?
doh
Post by doh »
Egregius wrote:And the 'has node failed' command in OZWCP?
I just get something like:
2016-12-28 15:39:36.696 Error, Node010, WARNING: node revived
2016-12-28 15:39:36.698 Always,
2016-12-28 15:39:36.699 Always, Dumping queued log messages
2016-12-28 15:39:36.701 Always,
2016-12-28 15:39:36.703 Always,
2016-12-28 15:39:36.704 Always, End of queued log message dump
2016-12-28 15:39:36.705 Always,
Egregius
Post by Egregius »
And node 10 stayed dead? Or is it back alive?
doh
Post by doh »
Egregius wrote:And node 10 stayed dead? Or is it back alive?
Still dead - same as all the other nodes.
Egregius
Post by Egregius »
Well, if that doesn't help, and also clean shutdown poweroff/on doesn't help I would hard reset the controller and all nodes.
Then include them one by one again. After all it's only 9 nodes. Not such a big deal.
doh
Post by doh »
Hmmm. I've done a factory reset and even firmware upgrade of the Z-Stick. I've also now done a fresh install of Domoticz from scratch. I've re-associated some of the nodes with the Z-stick again (but taking the Z-stick to them and pushing the button, etc.). When plugged back into the Raspberry Pi and Domoticz is started I still get the same issue (see image)
doh
Post by doh »
I've turned on debug for the Z-Stick (full dump below).
It looks like everything begins fine and then the node's dont send an Ack, so are then presumed dead after 3 retries.???
2016-12-28 16:49:27.433 Always, OpenZwave Version 1.4.2228 Starting Up
2016-12-28 16:49:27.435 Info, Setting Up Provided Network Key for Secure Communications
2016-12-28 16:49:27.437 Info, mgr,     Added driver for controller /dev/ttyUSB0
2016-12-28 16:49:27.441 Info,   Opening controller /dev/ttyUSB0
2016-12-28 16:49:27.443 Info, Trying to open serial port /dev/ttyUSB0 (attempt 1)
2016-12-28 16:49:27.448 Info, Serial port /dev/ttyUSB0 opened (attempt 1)
2016-12-28 16:49:27.450 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-12-28 16:49:27.452 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-12-28 16:49:27.453 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-12-28 16:49:27.455 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-12-28 16:49:27.457 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-12-28 16:49:27.458 Detail,
2016-12-28 16:49:27.460 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-12-28 16:49:27.466 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x32, 0x2e, 0x37, 0x38, 0x00, 0x01, 0x9b
2016-12-28 16:49:27.468 Detail,
2016-12-28 16:49:27.469 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2016-12-28 16:49:27.471 Info, contrlr,     Static Controller library, version Z-Wave 2.78
2016-12-28 16:49:27.472 Detail, Node045,   Expected reply was received
2016-12-28 16:49:27.473 Detail, Node045,   Message transaction complete
2016-12-28 16:49:27.475 Detail,
2016-12-28 16:49:27.476 Detail, contrlr, Removing current message
2016-12-28 16:49:27.478 Detail,
2016-12-28 16:49:27.479 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-12-28 16:49:27.485 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0x01, 0x84, 0xdf, 0x6e, 0x01, 0xe3
2016-12-28 16:49:27.487 Detail,
2016-12-28 16:49:27.488 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0x0184df6e.  Our node ID = 1
2016-12-28 16:49:27.489 Detail, Node132,   Expected reply was received
2016-12-28 16:49:27.491 Detail, Node132,   Message transaction complete
2016-12-28 16:49:27.492 Detail,
2016-12-28 16:49:27.494 Detail, contrlr, Removing current message
2016-12-28 16:49:27.495 Detail,
2016-12-28 16:49:27.497 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-12-28 16:49:27.501 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x1c, 0xe3
2016-12-28 16:49:27.503 Detail,
2016-12-28 16:49:27.504 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2016-12-28 16:49:27.505 Info, contrlr,     There is a SUC ID Server (SIS) in this network.
2016-12-28 16:49:27.506 Info, contrlr,     The PC controller is an inclusion static update controller (SUC) and was the original primary before the SIS was added.
2016-12-28 16:49:27.508 Detail, Node227,   Expected reply was received
2016-12-28 16:49:27.509 Detail, Node227,   Message transaction complete
2016-12-28 16:49:27.510 Detail,
2016-12-28 16:49:27.511 Detail, contrlr, Removing current message
2016-12-28 16:49:27.512 Detail,
2016-12-28 16:49:27.513 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-12-28 16:49:27.522 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x03, 0x07, 0x00, 0x86, 0x00, 0x02, 0x00, 0x01, 0xfe, 0x80, 0xfe, 0x88, 0x0f, 0x00, 0x00, 0x00, 0xfb, 0x97, 0x3f, 0x82, 0x07, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x82
2016-12-28 16:49:27.524 Detail,
2016-12-28 16:49:27.525 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2016-12-28 16:49:27.527 Info, contrlr,     Serial API Version:   3.7
2016-12-28 16:49:27.528 Info, contrlr,     Manufacturer ID:      0x0086
2016-12-28 16:49:27.531 Info, contrlr,     Product Type:         0x0002
2016-12-28 16:49:27.532 Info, contrlr,     Product ID:           0x0001
2016-12-28 16:49:27.534 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2016-12-28 16:49:27.536 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2016-12-28 16:49:27.537 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2016-12-28 16:49:27.539 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2016-12-28 16:49:27.541 Detail, Node007,   Expected reply was received
2016-12-28 16:49:27.542 Detail, Node007,   Message transaction complete
2016-12-28 16:49:27.543 Detail,
2016-12-28 16:49:27.543 Detail, contrlr, Removing current message
2016-12-28 16:49:27.545 Detail,
2016-12-28 16:49:27.546 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-12-28 16:49:27.552 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x01, 0xad
2016-12-28 16:49:27.553 Detail,
2016-12-28 16:49:27.555 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 1
2016-12-28 16:49:27.556 Detail, Node173,   Expected reply was received
2016-12-28 16:49:27.558 Detail, Node173,   Message transaction complete
2016-12-28 16:49:27.559 Detail,
2016-12-28 16:49:27.560 Detail, contrlr, Removing current message
2016-12-28 16:49:27.562 Detail,
2016-12-28 16:49:27.564 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2016-12-28 16:49:27.621 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xea, 0x9b, 0xf7, 0x2b, 0x04, 0x17, 0xb2, 0x34, 0xf5, 0x21, 0x66, 0xd8, 0xdc, 0x89, 0xe9, 0xe2, 0x4b, 0xe0, 0x06, 0x05, 0x2c, 0x1b, 0x76, 0xbc, 0xa4, 0xa8, 0x72, 0x76, 0xde, 0xa0, 0x9b, 0x3a, 0x68
2016-12-28 16:49:27.622 Detail,
2016-12-28 16:49:27.624 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2016-12-28 16:49:27.625 Detail, Node032,   Expected reply was received
2016-12-28 16:49:27.627 Detail, Node032,   Message transaction complete
2016-12-28 16:49:27.628 Detail,
2016-12-28 16:49:27.630 Detail, contrlr, Removing current message
2016-12-28 16:49:27.631 Detail,
2016-12-28 16:49:27.633 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2016-12-28 16:49:27.685 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x08, 0x1d, 0x01, 0x08, 0xc0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x05
2016-12-28 16:49:27.687 Detail,
2016-12-28 16:49:27.688 Info, mgr,     Driver with Home ID of 0x0184df6e is now ready.
2016-12-28 16:49:27.690 Info,
2016-12-28 16:49:27.704 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2016-12-28 16:49:27.705 Info, contrlr,     Node 001 - Known
2016-12-28 16:49:27.707 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-12-28 16:49:27.708 Detail, Node001, QueryStage_CacheLoad
2016-12-28 16:49:27.709 Info, Node001, Node Identity Codes: 0086:0002:0001
2016-12-28 16:49:27.711 Detail, Node001, QueryStage_Associations
2016-12-28 16:49:27.712 Detail, Node001, QueryStage_Neighbors
2016-12-28 16:49:27.714 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2016-12-28 16:49:27.715 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-12-28 16:49:27.717 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2016-12-28 16:49:27.719 Info, contrlr,     Node 012 - Known
2016-12-28 16:49:27.720 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2016-12-28 16:49:27.722 Detail, Node012, QueryStage_Probe
2016-12-28 16:49:27.723 Info, Node012, NoOperation::Set - Routing=true
2016-12-28 16:49:27.725 Detail, Node012, Queuing (NoOp) NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x1c, 0xd2
2016-12-28 16:49:27.726 Detail, Node012, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:27.728 Info, contrlr,     Node 023 - Known
2016-12-28 16:49:27.729 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2016-12-28 16:49:27.730 Detail, Node023, QueryStage_Probe
2016-12-28 16:49:27.731 Info, Node023, NoOperation::Set - Routing=true
2016-12-28 16:49:27.733 Detail, Node023, Queuing (NoOp) NoOperation_Set (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x00, 0x00, 0x25, 0x1d, 0xc8
2016-12-28 16:49:27.734 Detail, Node023, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:27.736 Info, contrlr,     Node 024 - Known
2016-12-28 16:49:27.737 Detail, Node024, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2016-12-28 16:49:27.739 Detail, Node024, QueryStage_Probe
2016-12-28 16:49:27.740 Info, Node024, NoOperation::Set - Routing=true
2016-12-28 16:49:27.741 Detail, Node024, Queuing (NoOp) NoOperation_Set (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x00, 0x00, 0x25, 0x1e, 0xc4
2016-12-28 16:49:27.743 Detail, Node024, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:27.744 Info, contrlr,     Node 025 - Known
2016-12-28 16:49:27.745 Detail, Node025, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2016-12-28 16:49:27.746 Detail, Node025, QueryStage_Probe
2016-12-28 16:49:27.748 Info, Node025, NoOperation::Set - Routing=true
2016-12-28 16:49:27.748 Detail, Node025, Queuing (NoOp) NoOperation_Set (Node=25): 0x01, 0x09, 0x00, 0x13, 0x19, 0x02, 0x00, 0x00, 0x25, 0x1f, 0xc4
2016-12-28 16:49:27.750 Detail, Node025, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:27.751 Info, contrlr,     Node 026 - Known
2016-12-28 16:49:27.752 Detail, Node026, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2016-12-28 16:49:27.753 Detail, Node026, QueryStage_Probe
2016-12-28 16:49:27.754 Info, Node026, NoOperation::Set - Routing=true
2016-12-28 16:49:27.755 Detail, Node026, Queuing (NoOp) NoOperation_Set (Node=26): 0x01, 0x09, 0x00, 0x13, 0x1a, 0x02, 0x00, 0x00, 0x25, 0x20, 0xf8
2016-12-28 16:49:27.757 Detail, Node026, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:27.758 Info, contrlr,     Node 027 - Known
2016-12-28 16:49:27.759 Detail, Node027, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2016-12-28 16:49:27.761 Detail, Node027, QueryStage_Probe
2016-12-28 16:49:27.762 Info, Node027, NoOperation::Set - Routing=true
2016-12-28 16:49:27.763 Detail, Node027, Queuing (NoOp) NoOperation_Set (Node=27): 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x00, 0x00, 0x25, 0x21, 0xf8
2016-12-28 16:49:27.765 Detail, Node027, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:27.766 Detail, Node008,   Expected reply was received
2016-12-28 16:49:27.768 Detail, Node008,   Message transaction complete
2016-12-28 16:49:27.769 Detail,
2016-12-28 16:49:27.770 Detail, contrlr, Removing current message
2016-12-28 16:49:27.771 Detail, Node001, Notification: DriverReady
2016-12-28 16:49:27.773 Detail, Node001, Notification: NodeAdded
2016-12-28 16:49:27.777 Detail, Node001, Notification: NodeProtocolInfo
2016-12-28 16:49:27.779 Detail, Node001, Notification: EssentialNodeQueriesComplete
2016-12-28 16:49:27.781 Detail, Node001, Notification: ValueAdded
2016-12-28 16:49:27.782 Detail, Node001, Notification: NodeNaming
2016-12-28 16:49:27.784 Detail, Node012, Notification: NodeAdded
2016-12-28 16:49:27.787 Detail, Node012, Notification: NodeProtocolInfo
2016-12-28 16:49:27.788 Detail, Node012, Notification: ValueAdded
2016-12-28 16:49:27.792 Detail, Node012, Notification: ValueAdded
2016-12-28 16:49:27.794 Detail, Node023, Notification: NodeAdded
2016-12-28 16:49:27.797 Detail, Node023, Notification: NodeProtocolInfo
2016-12-28 16:49:27.805 Detail, Node023, Notification: ValueAdded
2016-12-28 16:49:27.808 Detail, Node023, Notification: ValueAdded
2016-12-28 16:49:27.810 Detail, Node024, Notification: NodeAdded
2016-12-28 16:49:27.812 Detail, Node024, Notification: NodeProtocolInfo
2016-12-28 16:49:27.815 Detail, Node024, Notification: ValueAdded
2016-12-28 16:49:27.819 Detail, Node024, Notification: ValueAdded
2016-12-28 16:49:27.820 Detail, Node025, Notification: NodeAdded
2016-12-28 16:49:27.823 Detail, Node025, Notification: NodeProtocolInfo
2016-12-28 16:49:27.825 Detail, Node025, Notification: ValueAdded
2016-12-28 16:49:27.828 Detail, Node025, Notification: ValueAdded
2016-12-28 16:49:27.830 Detail, Node026, Notification: NodeAdded
2016-12-28 16:49:27.833 Detail, Node026, Notification: NodeProtocolInfo
2016-12-28 16:49:27.834 Detail, Node026, Notification: ValueAdded
2016-12-28 16:49:27.837 Detail, Node026, Notification: ValueAdded
2016-12-28 16:49:27.839 Detail, Node027, Notification: NodeAdded
2016-12-28 16:49:27.842 Detail, Node027, Notification: NodeProtocolInfo
2016-12-28 16:49:27.843 Detail, Node027, Notification: ValueAdded
2016-12-28 16:49:27.847 Detail, Node027, Notification: ValueAdded
2016-12-28 16:49:27.849 Detail,
2016-12-28 16:49:27.850 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2016-12-28 16:49:27.856 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2016-12-28 16:49:27.858 Detail,
2016-12-28 16:49:27.859 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2016-12-28 16:49:27.861 Detail, Node015,   Expected reply was received
2016-12-28 16:49:27.862 Detail, Node015,   Message transaction complete
2016-12-28 16:49:27.864 Detail,
2016-12-28 16:49:27.865 Detail, contrlr, Removing current message
2016-12-28 16:49:27.867 Detail,
2016-12-28 16:49:27.868 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2016-12-28 16:49:27.873 Detail, contrlr, Removing current message
2016-12-28 16:49:27.875 Detail,
2016-12-28 16:49:27.877 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-12-28 16:49:27.885 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x08, 0xc0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x91
2016-12-28 16:49:27.887 Detail,
2016-12-28 16:49:27.889 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2016-12-28 16:49:27.890 Info, Node001,     Neighbors of this node are:
2016-12-28 16:49:27.891 Info, Node001,     Node 12
2016-12-28 16:49:27.893 Info, Node001,     Node 23
2016-12-28 16:49:27.894 Info, Node001,     Node 24
2016-12-28 16:49:27.895 Info, Node001,     Node 25
2016-12-28 16:49:27.897 Info, Node001,     Node 26
2016-12-28 16:49:27.898 Info, Node001,     Node 27
2016-12-28 16:49:27.899 Detail, Node008,   Expected reply was received
2016-12-28 16:49:27.900 Detail, Node008,   Message transaction complete
2016-12-28 16:49:27.901 Detail,
2016-12-28 16:49:27.902 Detail, Node001, Removing current message
2016-12-28 16:49:27.903 Detail,
2016-12-28 16:49:27.905 Info, Node012, Sending (NoOp) message (Callback ID=0x1c, Expected Reply=0x13) - NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x1c, 0xd2
2016-12-28 16:49:27.912 Detail, Node012,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:27.914 Detail, Node012,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:28.089 Detail, Node012,   Received: 0x01, 0x05, 0x00, 0x13, 0x1c, 0x01, 0xf4
2016-12-28 16:49:28.091 Detail, Node012,   ZW_SEND_DATA Request with callback ID 0x1c received (expected 0x1c)
2016-12-28 16:49:28.092 Info, Node012, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:28.094 Warning, Node012, WARNING: Device is not a sleeping node.
2016-12-28 16:49:28.095 Info, Node012, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2016-12-28 16:49:28.097 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:28.098 Detail, Node001,   Expected reply was received
2016-12-28 16:49:28.100 Detail, Node001,   Message transaction complete
2016-12-28 16:49:28.101 Detail,
2016-12-28 16:49:28.102 Detail, Node012, Removing current message
2016-12-28 16:49:28.104 Detail, Node012, Notification: Notification - NoOperation
2016-12-28 16:49:28.106 Detail,
2016-12-28 16:49:28.107 Info, Node023, Sending (NoOp) message (Callback ID=0x1d, Expected Reply=0x13) - NoOperation_Set (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x00, 0x00, 0x25, 0x1d, 0xc8
2016-12-28 16:49:28.115 Detail, Node023,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:28.117 Detail, Node023,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:28.251 Detail, Node023,   Received: 0x01, 0x05, 0x00, 0x13, 0x1d, 0x01, 0xf5
2016-12-28 16:49:28.252 Detail, Node023,   ZW_SEND_DATA Request with callback ID 0x1d received (expected 0x1d)
2016-12-28 16:49:28.254 Info, Node023, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:28.256 Warning, Node023, WARNING: Device is not a sleeping node.
2016-12-28 16:49:28.257 Info, Node023, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2016-12-28 16:49:28.259 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:28.260 Detail, Node001,   Expected reply was received
2016-12-28 16:49:28.262 Detail, Node001,   Message transaction complete
2016-12-28 16:49:28.263 Detail,
2016-12-28 16:49:28.265 Detail, Node023, Removing current message
2016-12-28 16:49:28.266 Detail, Node023, Notification: Notification - NoOperation
2016-12-28 16:49:28.268 Detail,
2016-12-28 16:49:28.270 Info, Node024, Sending (NoOp) message (Callback ID=0x1e, Expected Reply=0x13) - NoOperation_Set (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x00, 0x00, 0x25, 0x1e, 0xc4
2016-12-28 16:49:28.278 Detail, Node024,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:28.280 Detail, Node024,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:29.374 Detail, Node024,   Received: 0x01, 0x05, 0x00, 0x13, 0x1e, 0x01, 0xf6
2016-12-28 16:49:29.375 Detail, Node024,   ZW_SEND_DATA Request with callback ID 0x1e received (expected 0x1e)
2016-12-28 16:49:29.377 Info, Node024, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:29.378 Warning, Node024, WARNING: Device is not a sleeping node.
2016-12-28 16:49:29.380 Info, Node024, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2016-12-28 16:49:29.383 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:29.385 Detail, Node001,   Expected reply was received
2016-12-28 16:49:29.386 Detail, Node001,   Message transaction complete
2016-12-28 16:49:29.388 Detail,
2016-12-28 16:49:29.389 Detail, Node024, Removing current message
2016-12-28 16:49:29.391 Detail, Node024, Notification: Notification - NoOperation
2016-12-28 16:49:29.393 Detail,
2016-12-28 16:49:29.394 Info, Node025, Sending (NoOp) message (Callback ID=0x1f, Expected Reply=0x13) - NoOperation_Set (Node=25): 0x01, 0x09, 0x00, 0x13, 0x19, 0x02, 0x00, 0x00, 0x25, 0x1f, 0xc4
2016-12-28 16:49:29.402 Detail, Node025,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:29.404 Detail, Node025,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:29.559 Detail, Node025,   Received: 0x01, 0x05, 0x00, 0x13, 0x1f, 0x01, 0xf7
2016-12-28 16:49:29.561 Detail, Node025,   ZW_SEND_DATA Request with callback ID 0x1f received (expected 0x1f)
2016-12-28 16:49:29.562 Info, Node025, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:29.564 Warning, Node025, WARNING: Device is not a sleeping node.
2016-12-28 16:49:29.565 Info, Node025, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2016-12-28 16:49:29.567 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:29.568 Detail, Node001,   Expected reply was received
2016-12-28 16:49:29.570 Detail, Node001,   Message transaction complete
2016-12-28 16:49:29.571 Detail,
2016-12-28 16:49:29.572 Detail, Node025, Removing current message
2016-12-28 16:49:29.574 Detail, Node025, Notification: Notification - NoOperation
2016-12-28 16:49:29.576 Detail,
2016-12-28 16:49:29.577 Info, Node026, Sending (NoOp) message (Callback ID=0x20, Expected Reply=0x13) - NoOperation_Set (Node=26): 0x01, 0x09, 0x00, 0x13, 0x1a, 0x02, 0x00, 0x00, 0x25, 0x20, 0xf8
2016-12-28 16:49:29.585 Detail, Node026,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:29.587 Detail, Node026,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:30.759 Detail, Node026,   Received: 0x01, 0x05, 0x00, 0x13, 0x20, 0x01, 0xc8
2016-12-28 16:49:30.761 Detail, Node026,   ZW_SEND_DATA Request with callback ID 0x20 received (expected 0x20)
2016-12-28 16:49:30.763 Info, Node026, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:30.764 Warning, Node026, WARNING: Device is not a sleeping node.
2016-12-28 16:49:30.766 Info, Node026, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2016-12-28 16:49:30.768 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:30.769 Detail, Node001,   Expected reply was received
2016-12-28 16:49:30.770 Detail, Node001,   Message transaction complete
2016-12-28 16:49:30.772 Detail,
2016-12-28 16:49:30.773 Detail, Node026, Removing current message
2016-12-28 16:49:30.775 Detail, Node026, Notification: Notification - NoOperation
2016-12-28 16:49:30.777 Detail,
2016-12-28 16:49:30.778 Info, Node027, Sending (NoOp) message (Callback ID=0x21, Expected Reply=0x13) - NoOperation_Set (Node=27): 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x00, 0x00, 0x25, 0x21, 0xf8
2016-12-28 16:49:30.786 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:30.788 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:30.901 Detail, Node027,   Received: 0x01, 0x05, 0x00, 0x13, 0x21, 0x01, 0xc9
2016-12-28 16:49:30.903 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x21 received (expected 0x21)
2016-12-28 16:49:30.904 Info, Node027, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:30.906 Warning, Node027, WARNING: Device is not a sleeping node.
2016-12-28 16:49:30.907 Info, Node027, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2016-12-28 16:49:30.909 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:30.911 Detail, Node001,   Expected reply was received
2016-12-28 16:49:30.912 Detail, Node001,   Message transaction complete
2016-12-28 16:49:30.913 Detail,
2016-12-28 16:49:30.915 Detail, Node027, Removing current message
2016-12-28 16:49:30.917 Detail, Node027, Notification: Notification - NoOperation
2016-12-28 16:49:30.919 Detail, Node001, Query Stage Complete (Neighbors)
2016-12-28 16:49:30.920 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2016-12-28 16:49:30.922 Detail, Node001, QueryStage_Session
2016-12-28 16:49:30.923 Detail, Node001, QueryStage_Dynamic
2016-12-28 16:49:30.924 Detail, Node001, QueryStage_Configuration
2016-12-28 16:49:30.926 Detail, Node001, QueryStage_Complete
2016-12-28 16:49:30.926 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:30.928 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=0
2016-12-28 16:49:30.930 Detail, Node001, Notification: NodeQueriesComplete
2016-12-28 16:49:30.932 Detail, Node012, Query Stage Complete (Probe)
2016-12-28 16:49:30.934 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2016-12-28 16:49:30.935 Detail, Node012, QueryStage_Probe
2016-12-28 16:49:30.937 Info, Node012, NoOperation::Set - Routing=true
2016-12-28 16:49:30.938 Detail, Node012, Queuing (NoOp) NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x22, 0xec
2016-12-28 16:49:30.940 Detail, Node012, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:30.941 Detail,
2016-12-28 16:49:30.943 Info, Node012, Sending (NoOp) message (Callback ID=0x22, Expected Reply=0x13) - NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x22, 0xec
2016-12-28 16:49:30.951 Detail, Node012,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:30.953 Detail, Node012,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:31.088 Detail, Node012,   Received: 0x01, 0x05, 0x00, 0x13, 0x22, 0x01, 0xca
2016-12-28 16:49:31.090 Detail, Node012,   ZW_SEND_DATA Request with callback ID 0x22 received (expected 0x22)
2016-12-28 16:49:31.091 Info, Node012, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:31.093 Warning, Node012, WARNING: Device is not a sleeping node.
2016-12-28 16:49:31.094 Info, Node012, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2016-12-28 16:49:31.096 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:31.097 Detail, Node001,   Expected reply was received
2016-12-28 16:49:31.099 Detail, Node001,   Message transaction complete
2016-12-28 16:49:31.100 Detail,
2016-12-28 16:49:31.102 Detail, Node012, Removing current message
2016-12-28 16:49:31.103 Detail, Node012, Notification: Notification - NoOperation
2016-12-28 16:49:31.105 Detail, Node023, Query Stage Complete (Probe)
2016-12-28 16:49:31.106 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2016-12-28 16:49:31.108 Detail, Node023, QueryStage_Probe
2016-12-28 16:49:31.110 Info, Node023, NoOperation::Set - Routing=true
2016-12-28 16:49:31.111 Detail, Node023, Queuing (NoOp) NoOperation_Set (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x00, 0x00, 0x25, 0x23, 0xf6
2016-12-28 16:49:31.113 Detail, Node023, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:31.115 Detail,
2016-12-28 16:49:31.116 Info, Node023, Sending (NoOp) message (Callback ID=0x23, Expected Reply=0x13) - NoOperation_Set (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x00, 0x00, 0x25, 0x23, 0xf6
2016-12-28 16:49:31.125 Detail, Node023,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:31.126 Detail, Node023,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:31.219 Detail, Node023,   Received: 0x01, 0x05, 0x00, 0x13, 0x23, 0x01, 0xcb
2016-12-28 16:49:31.221 Detail, Node023,   ZW_SEND_DATA Request with callback ID 0x23 received (expected 0x23)
2016-12-28 16:49:31.223 Info, Node023, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:31.225 Warning, Node023, WARNING: Device is not a sleeping node.
2016-12-28 16:49:31.228 Info, Node023, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2016-12-28 16:49:31.229 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:31.231 Detail, Node001,   Expected reply was received
2016-12-28 16:49:31.233 Detail, Node001,   Message transaction complete
2016-12-28 16:49:31.234 Detail,
2016-12-28 16:49:31.235 Detail, Node023, Removing current message
2016-12-28 16:49:31.237 Detail, Node023, Notification: Notification - NoOperation
2016-12-28 16:49:31.239 Detail, Node024, Query Stage Complete (Probe)
2016-12-28 16:49:31.240 Detail, Node024, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2016-12-28 16:49:31.241 Detail, Node024, QueryStage_Probe
2016-12-28 16:49:31.243 Info, Node024, NoOperation::Set - Routing=true
2016-12-28 16:49:31.243 Detail, Node024, Queuing (NoOp) NoOperation_Set (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x00, 0x00, 0x25, 0x24, 0xfe
2016-12-28 16:49:31.245 Detail, Node024, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:31.246 Detail,
2016-12-28 16:49:31.248 Info, Node024, Sending (NoOp) message (Callback ID=0x24, Expected Reply=0x13) - NoOperation_Set (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x00, 0x00, 0x25, 0x24, 0xfe
2016-12-28 16:49:31.257 Detail, Node024,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:31.259 Detail, Node024,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:32.471 Detail, Node024,   Received: 0x01, 0x05, 0x00, 0x13, 0x24, 0x01, 0xcc
2016-12-28 16:49:32.490 Detail, Node024,   ZW_SEND_DATA Request with callback ID 0x24 received (expected 0x24)
2016-12-28 16:49:32.492 Info, Node024, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:32.493 Warning, Node024, WARNING: Device is not a sleeping node.
2016-12-28 16:49:32.495 Info, Node024, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2016-12-28 16:49:32.496 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:32.498 Detail, Node001,   Expected reply was received
2016-12-28 16:49:32.499 Detail, Node001,   Message transaction complete
2016-12-28 16:49:32.501 Detail,
2016-12-28 16:49:32.502 Detail, Node024, Removing current message
2016-12-28 16:49:32.504 Detail, Node024, Notification: Notification - NoOperation
2016-12-28 16:49:32.506 Detail, Node025, Query Stage Complete (Probe)
2016-12-28 16:49:32.507 Detail, Node025, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2016-12-28 16:49:32.509 Detail, Node025, QueryStage_Probe
2016-12-28 16:49:32.510 Info, Node025, NoOperation::Set - Routing=true
2016-12-28 16:49:32.511 Detail, Node025, Queuing (NoOp) NoOperation_Set (Node=25): 0x01, 0x09, 0x00, 0x13, 0x19, 0x02, 0x00, 0x00, 0x25, 0x25, 0xfe
2016-12-28 16:49:32.513 Detail, Node025, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:32.514 Detail,
2016-12-28 16:49:32.516 Info, Node025, Sending (NoOp) message (Callback ID=0x25, Expected Reply=0x13) - NoOperation_Set (Node=25): 0x01, 0x09, 0x00, 0x13, 0x19, 0x02, 0x00, 0x00, 0x25, 0x25, 0xfe
2016-12-28 16:49:32.524 Detail, Node025,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:32.526 Detail, Node025,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:32.619 Detail, Node025,   Received: 0x01, 0x05, 0x00, 0x13, 0x25, 0x01, 0xcd
2016-12-28 16:49:32.621 Detail, Node025,   ZW_SEND_DATA Request with callback ID 0x25 received (expected 0x25)
2016-12-28 16:49:32.622 Info, Node025, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:32.624 Warning, Node025, WARNING: Device is not a sleeping node.
2016-12-28 16:49:32.625 Info, Node025, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2016-12-28 16:49:32.627 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:32.628 Detail, Node001,   Expected reply was received
2016-12-28 16:49:32.630 Detail, Node001,   Message transaction complete
2016-12-28 16:49:32.631 Detail,
2016-12-28 16:49:32.632 Detail, Node025, Removing current message
2016-12-28 16:49:32.634 Detail, Node025, Notification: Notification - NoOperation
2016-12-28 16:49:32.636 Detail, Node026, Query Stage Complete (Probe)
2016-12-28 16:49:32.638 Detail, Node026, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2016-12-28 16:49:32.640 Detail, Node026, QueryStage_Probe
2016-12-28 16:49:32.641 Info, Node026, NoOperation::Set - Routing=true
2016-12-28 16:49:32.642 Detail, Node026, Queuing (NoOp) NoOperation_Set (Node=26): 0x01, 0x09, 0x00, 0x13, 0x1a, 0x02, 0x00, 0x00, 0x25, 0x26, 0xfe
2016-12-28 16:49:32.643 Detail, Node026, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:32.645 Detail,
2016-12-28 16:49:32.646 Info, Node026, Sending (NoOp) message (Callback ID=0x26, Expected Reply=0x13) - NoOperation_Set (Node=26): 0x01, 0x09, 0x00, 0x13, 0x1a, 0x02, 0x00, 0x00, 0x25, 0x26, 0xfe
2016-12-28 16:49:32.654 Detail, Node026,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:32.656 Detail, Node026,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:33.850 Detail, Node026,   Received: 0x01, 0x05, 0x00, 0x13, 0x26, 0x01, 0xce
2016-12-28 16:49:33.851 Detail, Node026,   ZW_SEND_DATA Request with callback ID 0x26 received (expected 0x26)
2016-12-28 16:49:33.853 Info, Node026, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:33.854 Warning, Node026, WARNING: Device is not a sleeping node.
2016-12-28 16:49:33.856 Info, Node026, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2016-12-28 16:49:33.857 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:33.859 Detail, Node001,   Expected reply was received
2016-12-28 16:49:33.860 Detail, Node001,   Message transaction complete
2016-12-28 16:49:33.861 Detail,
2016-12-28 16:49:33.863 Detail, Node026, Removing current message
2016-12-28 16:49:33.865 Detail, Node026, Notification: Notification - NoOperation
2016-12-28 16:49:33.866 Detail, Node027, Query Stage Complete (Probe)
2016-12-28 16:49:33.868 Detail, Node027, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2016-12-28 16:49:33.869 Detail, Node027, QueryStage_Probe
2016-12-28 16:49:33.871 Info, Node027, NoOperation::Set - Routing=true
2016-12-28 16:49:33.872 Detail, Node027, Queuing (NoOp) NoOperation_Set (Node=27): 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x00, 0x00, 0x25, 0x27, 0xfe
2016-12-28 16:49:33.874 Detail, Node027, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:33.875 Detail,
2016-12-28 16:49:33.877 Info, Node027, Sending (NoOp) message (Callback ID=0x27, Expected Reply=0x13) - NoOperation_Set (Node=27): 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x00, 0x00, 0x25, 0x27, 0xfe
2016-12-28 16:49:33.885 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:33.887 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:34.000 Detail, Node027,   Received: 0x01, 0x05, 0x00, 0x13, 0x27, 0x01, 0xcf
2016-12-28 16:49:34.002 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x27 received (expected 0x27)
2016-12-28 16:49:34.003 Info, Node027, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:34.005 Warning, Node027, WARNING: Device is not a sleeping node.
2016-12-28 16:49:34.007 Info, Node027, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2016-12-28 16:49:34.008 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:34.010 Detail, Node001,   Expected reply was received
2016-12-28 16:49:34.011 Detail, Node001,   Message transaction complete
2016-12-28 16:49:34.013 Detail,
2016-12-28 16:49:34.014 Detail, Node027, Removing current message
2016-12-28 16:49:34.016 Detail, Node027, Notification: Notification - NoOperation
2016-12-28 16:49:34.018 Detail, Node012, Query Stage Complete (Probe)
2016-12-28 16:49:34.020 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2016-12-28 16:49:34.022 Detail, Node012, QueryStage_Probe
2016-12-28 16:49:34.023 Info, Node012, NoOperation::Set - Routing=true
2016-12-28 16:49:34.024 Detail, Node012, Queuing (NoOp) NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x28, 0xe6
2016-12-28 16:49:34.026 Detail, Node012, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:34.028 Detail,
2016-12-28 16:49:34.029 Info, Node012, Sending (NoOp) message (Callback ID=0x28, Expected Reply=0x13) - NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x28, 0xe6
2016-12-28 16:49:34.038 Detail, Node012,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:34.039 Detail, Node012,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:34.193 Detail, Node012,   Received: 0x01, 0x05, 0x00, 0x13, 0x28, 0x01, 0xc0
2016-12-28 16:49:34.195 Detail, Node012,   ZW_SEND_DATA Request with callback ID 0x28 received (expected 0x28)
2016-12-28 16:49:34.196 Info, Node012, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:34.198 Warning, Node012, WARNING: Device is not a sleeping node.
2016-12-28 16:49:34.200 Error, Node012, ERROR: node presumed dead
2016-12-28 16:49:34.201 Always,
2016-12-28 16:49:34.203 Always, Dumping queued log messages
2016-12-28 16:49:34.204 Always,
2016-12-28 16:49:34.207 Always,
2016-12-28 16:49:34.208 Always, End of queued log message dump
2016-12-28 16:49:34.209 Always,
2016-12-28 16:49:34.211 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:34.212 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2016-12-28 16:49:34.213 Info, Node012, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2016-12-28 16:49:34.215 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:34.216 Detail, Node001,   Expected reply was received
2016-12-28 16:49:34.218 Detail, Node001,   Message transaction complete
2016-12-28 16:49:34.219 Detail,
2016-12-28 16:49:34.221 Detail, Node012, Removing current message
2016-12-28 16:49:34.222 Detail, Node012, Notification: Notification - NoOperation
2016-12-28 16:49:34.224 Detail, Node012, Notification: Notification - Node Dead
2016-12-28 16:49:34.232 Detail, Node023, Query Stage Complete (Probe)
2016-12-28 16:49:34.233 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2016-12-28 16:49:34.234 Detail, Node023, QueryStage_Probe
2016-12-28 16:49:34.236 Info, Node023, NoOperation::Set - Routing=true
2016-12-28 16:49:34.238 Detail, Node023, Queuing (NoOp) NoOperation_Set (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x00, 0x00, 0x25, 0x29, 0xfc
2016-12-28 16:49:34.243 Detail, Node023, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:34.245 Detail,
2016-12-28 16:49:34.246 Info, Node023, Sending (NoOp) message (Callback ID=0x29, Expected Reply=0x13) - NoOperation_Set (Node=23): 0x01, 0x09, 0x00, 0x13, 0x17, 0x02, 0x00, 0x00, 0x25, 0x29, 0xfc
2016-12-28 16:49:34.254 Detail, Node023,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:34.256 Detail, Node023,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:34.412 Detail, Node023,   Received: 0x01, 0x05, 0x00, 0x13, 0x29, 0x01, 0xc1
2016-12-28 16:49:34.414 Detail, Node023,   ZW_SEND_DATA Request with callback ID 0x29 received (expected 0x29)
2016-12-28 16:49:34.415 Info, Node023, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:34.417 Warning, Node023, WARNING: Device is not a sleeping node.
2016-12-28 16:49:34.418 Error, Node023, ERROR: node presumed dead
2016-12-28 16:49:34.420 Always,
2016-12-28 16:49:34.421 Always, Dumping queued log messages
2016-12-28 16:49:34.423 Always,
2016-12-28 16:49:34.425 Always,
2016-12-28 16:49:34.427 Always, End of queued log message dump
2016-12-28 16:49:34.428 Always,
2016-12-28 16:49:34.429 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:34.431 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2016-12-28 16:49:34.433 Info, Node023, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2016-12-28 16:49:34.434 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:34.436 Detail, Node001,   Expected reply was received
2016-12-28 16:49:34.438 Detail, Node001,   Message transaction complete
2016-12-28 16:49:34.439 Detail,
2016-12-28 16:49:34.439 Detail, Node023, Removing current message
2016-12-28 16:49:34.441 Detail, Node023, Notification: Notification - NoOperation
2016-12-28 16:49:34.442 Detail, Node023, Notification: Notification - Node Dead
2016-12-28 16:49:34.455 Detail, Node024, Query Stage Complete (Probe)
2016-12-28 16:49:34.456 Detail, Node024, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2016-12-28 16:49:34.458 Detail, Node024, QueryStage_Probe
2016-12-28 16:49:34.459 Info, Node024, NoOperation::Set - Routing=true
2016-12-28 16:49:34.461 Detail, Node024, Queuing (NoOp) NoOperation_Set (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x00, 0x00, 0x25, 0x2a, 0xf0
2016-12-28 16:49:34.463 Detail, Node024, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:34.465 Detail,
2016-12-28 16:49:34.466 Info, Node024, Sending (NoOp) message (Callback ID=0x2a, Expected Reply=0x13) - NoOperation_Set (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x00, 0x00, 0x25, 0x2a, 0xf0
2016-12-28 16:49:34.475 Detail, Node024,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:34.477 Detail, Node024,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:35.610 Detail, Node024,   Received: 0x01, 0x05, 0x00, 0x13, 0x2a, 0x01, 0xc2
2016-12-28 16:49:35.612 Detail, Node024,   ZW_SEND_DATA Request with callback ID 0x2a received (expected 0x2a)
2016-12-28 16:49:35.613 Info, Node024, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:35.615 Warning, Node024, WARNING: Device is not a sleeping node.
2016-12-28 16:49:35.616 Error, Node024, ERROR: node presumed dead
2016-12-28 16:49:35.618 Always,
2016-12-28 16:49:35.619 Always, Dumping queued log messages
2016-12-28 16:49:35.620 Always,
2016-12-28 16:49:35.623 Always,
2016-12-28 16:49:35.624 Always, End of queued log message dump
2016-12-28 16:49:35.625 Always,
2016-12-28 16:49:35.627 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:35.628 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2016-12-28 16:49:35.630 Info, Node024, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2016-12-28 16:49:35.631 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:35.632 Detail, Node001,   Expected reply was received
2016-12-28 16:49:35.634 Detail, Node001,   Message transaction complete
2016-12-28 16:49:35.635 Detail,
2016-12-28 16:49:35.637 Detail, Node024, Removing current message
2016-12-28 16:49:35.639 Detail, Node024, Notification: Notification - NoOperation
2016-12-28 16:49:35.640 Detail, Node024, Notification: Notification - Node Dead
2016-12-28 16:49:35.649 Detail, Node025, Query Stage Complete (Probe)
2016-12-28 16:49:35.650 Detail, Node025, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2016-12-28 16:49:35.652 Detail, Node025, QueryStage_Probe
2016-12-28 16:49:35.653 Info, Node025, NoOperation::Set - Routing=true
2016-12-28 16:49:35.655 Detail, Node025, Queuing (NoOp) NoOperation_Set (Node=25): 0x01, 0x09, 0x00, 0x13, 0x19, 0x02, 0x00, 0x00, 0x25, 0x2b, 0xf0
2016-12-28 16:49:35.656 Detail, Node025, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:35.662 Detail,
2016-12-28 16:49:35.663 Info, Node025, Sending (NoOp) message (Callback ID=0x2b, Expected Reply=0x13) - NoOperation_Set (Node=25): 0x01, 0x09, 0x00, 0x13, 0x19, 0x02, 0x00, 0x00, 0x25, 0x2b, 0xf0
2016-12-28 16:49:35.671 Detail, Node025,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:35.673 Detail, Node025,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:35.788 Detail, Node025,   Received: 0x01, 0x05, 0x00, 0x13, 0x2b, 0x01, 0xc3
2016-12-28 16:49:35.790 Detail, Node025,   ZW_SEND_DATA Request with callback ID 0x2b received (expected 0x2b)
2016-12-28 16:49:35.791 Info, Node025, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:35.793 Warning, Node025, WARNING: Device is not a sleeping node.
2016-12-28 16:49:35.794 Error, Node025, ERROR: node presumed dead
2016-12-28 16:49:35.796 Always,
2016-12-28 16:49:35.797 Always, Dumping queued log messages
2016-12-28 16:49:35.799 Always,
2016-12-28 16:49:35.801 Always,
2016-12-28 16:49:35.803 Always, End of queued log message dump
2016-12-28 16:49:35.804 Always,
2016-12-28 16:49:35.806 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:35.807 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2016-12-28 16:49:35.808 Info, Node025, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2016-12-28 16:49:35.810 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:35.812 Detail, Node001,   Expected reply was received
2016-12-28 16:49:35.813 Detail, Node001,   Message transaction complete
2016-12-28 16:49:35.815 Detail,
2016-12-28 16:49:35.816 Detail, Node025, Removing current message
2016-12-28 16:49:35.818 Detail, Node025, Notification: Notification - NoOperation
2016-12-28 16:49:35.820 Detail, Node025, Notification: Notification - Node Dead
2016-12-28 16:49:35.825 Detail, Node026, Query Stage Complete (Probe)
2016-12-28 16:49:35.833 Detail, Node026, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2016-12-28 16:49:35.835 Detail, Node026, QueryStage_Probe
2016-12-28 16:49:35.836 Info, Node026, NoOperation::Set - Routing=true
2016-12-28 16:49:35.838 Detail, Node026, Queuing (NoOp) NoOperation_Set (Node=26): 0x01, 0x09, 0x00, 0x13, 0x1a, 0x02, 0x00, 0x00, 0x25, 0x2c, 0xf4
2016-12-28 16:49:35.840 Detail, Node026, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:35.841 Detail,
2016-12-28 16:49:35.843 Info, Node026, Sending (NoOp) message (Callback ID=0x2c, Expected Reply=0x13) - NoOperation_Set (Node=26): 0x01, 0x09, 0x00, 0x13, 0x1a, 0x02, 0x00, 0x00, 0x25, 0x2c, 0xf4
2016-12-28 16:49:35.852 Detail, Node026,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:35.854 Detail, Node026,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:37.026 Detail, Node026,   Received: 0x01, 0x05, 0x00, 0x13, 0x2c, 0x01, 0xc4
2016-12-28 16:49:37.028 Detail, Node026,   ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
2016-12-28 16:49:37.029 Info, Node026, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:37.031 Warning, Node026, WARNING: Device is not a sleeping node.
2016-12-28 16:49:37.032 Error, Node026, ERROR: node presumed dead
2016-12-28 16:49:37.033 Always,
2016-12-28 16:49:37.035 Always, Dumping queued log messages
2016-12-28 16:49:37.036 Always,
2016-12-28 16:49:37.039 Always,
2016-12-28 16:49:37.040 Always, End of queued log message dump
2016-12-28 16:49:37.041 Always,
2016-12-28 16:49:37.042 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:37.044 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2016-12-28 16:49:37.045 Info, Node026, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2016-12-28 16:49:37.046 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:37.047 Detail, Node001,   Expected reply was received
2016-12-28 16:49:37.048 Detail, Node001,   Message transaction complete
2016-12-28 16:49:37.049 Detail,
2016-12-28 16:49:37.050 Detail, Node026, Removing current message
2016-12-28 16:49:37.051 Detail, Node026, Notification: Notification - NoOperation
2016-12-28 16:49:37.053 Detail, Node026, Notification: Notification - Node Dead
2016-12-28 16:49:37.064 Detail, Node027, Query Stage Complete (Probe)
2016-12-28 16:49:37.066 Detail, Node027, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2016-12-28 16:49:37.067 Detail, Node027, QueryStage_Probe
2016-12-28 16:49:37.068 Info, Node027, NoOperation::Set - Routing=true
2016-12-28 16:49:37.069 Detail, Node027, Queuing (NoOp) NoOperation_Set (Node=27): 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x00, 0x00, 0x25, 0x2d, 0xf4
2016-12-28 16:49:37.070 Detail, Node027, Queuing (Query) Query Stage Complete (Probe)
2016-12-28 16:49:37.072 Detail,
2016-12-28 16:49:37.073 Info, Node027, Sending (NoOp) message (Callback ID=0x2d, Expected Reply=0x13) - NoOperation_Set (Node=27): 0x01, 0x09, 0x00, 0x13, 0x1b, 0x02, 0x00, 0x00, 0x25, 0x2d, 0xf4
2016-12-28 16:49:37.080 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-28 16:49:37.081 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2016-12-28 16:49:37.236 Detail, Node027,   Received: 0x01, 0x05, 0x00, 0x13, 0x2d, 0x01, 0xc5
2016-12-28 16:49:37.238 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2016-12-28 16:49:37.239 Info, Node027, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-28 16:49:37.240 Warning, Node027, WARNING: Device is not a sleeping node.
2016-12-28 16:49:37.241 Error, Node027, ERROR: node presumed dead
2016-12-28 16:49:37.243 Always,
2016-12-28 16:49:37.244 Always, Dumping queued log messages
2016-12-28 16:49:37.245 Always,
2016-12-28 16:49:37.247 Always,
2016-12-28 16:49:37.248 Always, End of queued log message dump
2016-12-28 16:49:37.249 Always,
2016-12-28 16:49:37.250 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-28 16:49:37.251 Warning, CheckCompletedNodeQueries all=1, deadFound=1 sleepingOnly=1
2016-12-28 16:49:37.252 Info,          Node query processing complete except for dead nodes.
2016-12-28 16:49:37.253 Info, Node027, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2016-12-28 16:49:37.254 Detail, Node001,   Expected callbackId was received
2016-12-28 16:49:37.255 Detail, Node001,   Expected reply was received
2016-12-28 16:49:37.256 Detail, Node001,   Message transaction complete
2016-12-28 16:49:37.257 Detail,
2016-12-28 16:49:37.258 Detail, Node027, Removing current message
2016-12-28 16:49:37.259 Detail, Node027, Notification: Notification - NoOperation
2016-12-28 16:49:37.260 Detail, contrlr, Notification: AllNodesQueriedSomeDead
2016-12-28 16:49:37.261 Detail, Node027, Notification: Notification - Node Dead
2016-12-28 16:49:37.273 Detail, Node012, Query Stage Complete (Probe)
2016-12-28 16:49:37.274 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
2016-12-28 16:49:37.275 Detail, Node023, Query Stage Complete (Probe)
2016-12-28 16:49:37.276 Detail, Node023, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
2016-12-28 16:49:37.277 Detail, Node024, Query Stage Complete (Probe)
2016-12-28 16:49:37.278 Detail, Node024, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
2016-12-28 16:49:37.280 Detail, Node025, Query Stage Complete (Probe)
2016-12-28 16:49:37.281 Detail, Node025, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
2016-12-28 16:49:37.282 Detail, Node026, Query Stage Complete (Probe)
2016-12-28 16:49:37.283 Detail, Node026, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
2016-12-28 16:49:37.284 Detail, Node027, Query Stage Complete (Probe)
2016-12-28 16:49:37.285 Detail, Node027, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
doh
Post by doh »
ok, so, don't know what's going on - I tried everything and nothing worked and then... it's started working again. No idea what's changed, but it's now working and I can setup all the devices again.
