My "old" sensor bus uses loads of DS1820 sensors and other 1-wire devices, connected to the raspberry pi through some DS2482-800 - 8-Channel 1-Wire Master chips. These are connected to the rpi through the I2C bus, which works great..
Does domoticz support the use of these chips directly ? or only through the use of OWFS ?
Use proper 1-wire master - DS2482-800 - with Domoticz ?
Moderators: fantom, leecollings
djmoon
Re: Use proper 1-wire master - DS2482-800 - with Domoticz ?
I've such a chip too with a Rpi and it work fine now from... yesterday !
I don't find other solution than OWFS.
In resume :
Configure I2C
Installing OWFS
Create proper folder
Setup OWFS
Put OWFS on startup
Reboot
In domoticz, Add a "One Wire" hardware that can read value directly in the folder previously created for OWFS.
Complete guide :
Installation OWFS (not sure python-ow needed)
sudo apt-get install owfs python-ow
Config :
sudo nano /etc/owfs.conf
Comment out the following line
# server: FAKE = DS18S20,DS2405
Find the following section
# USB device: DS9490
#server: usb = all
Insert the line below to enable i2c support.
server: device = /dev/i2c-1
Find the section titled
######################### OWFS ##########################
Remove the hashes from the lines
mountpoint = /mnt/1wire
allow_other
Save your changes and exit the nano editor.
Create destination folder
sudo mkdir /mnt/1wire
To make it possible to access the 1wire devices without root privileges you'll have to modify the FUSE settings. Open the fuse configuration file:
sudo nano /etc/fuse.conf
Change
#user_allow_other
to
user_allow_other
Launch OWFS
sudo owfs --i2c=ALL:ALL --allow_other /mnt/1wire/
Autorun OWFS
Create the startup script in /etc/init.d/
cd /etc/init.d
sudo nano start1wire.sh
Add the folowing to the file (remove the first space on each row):
#!/bin/bash
### BEGIN INIT INFO
# Provides: start1wire
# Required-Start: $local_fs $syslog
# Required-Stop: $local_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start OWFS at boot time
# Description: Start OWFS at boot time
### END INIT INFO
# Starts OWFS
To make the script executable, run the following command:
sudo chmod +x start1wire.sh
Add the script to the default runlevel.
sudo update-rc.d start1wire.sh defaults
In resume :
Configure I2C
Installing OWFS
Setup OWFS
Put OWFS on startup
Reboot
Complete guide :
Config :
#server: usb = all
allow_other
Change
#user_allow_other
to
user_allow_other
Launch OWFS
Autorun OWFS
cd /etc/init.d
#!/bin/bash
### BEGIN INIT INFO
### END INIT INFO
# Starts OWFS
- Redguy
- Domoticz version: 3.5877
I have had such a system active for quite a while connected to my pi before switching to domoticz, mainly for monitoring temperatures in my heating systems and guarding my water leakage sensors etc..
i am in doubt about reusing the system or converting the "hub" nodes in that network to MySensors nodes, but i find using 1-wire devices with arduinos a huge pain in the butt compared to OWFS.
Lomax
That's a great guide! Just one detail: I don't think you need to pass any arguments to owfs when starting it - these are already set in the owfs.conf file. In my init.d script I only have "owfs" where you have "owfs --i2c=ALL:ALL --allow_other /mnt/1wire" and this seems to work just the same (provided that those settings have been made in owfs.conf of course).djmoon wrote:Hi,
In resume :
Configure I2C
Installing OWFS
Setup OWFS
Put OWFS on startup
Reboot
