Activate switch when there is solar excess production
sovking
Post by sovking »
I would like to use event for activate a switch connected to a load (my PDC) when there is solar production.
I'have already:
  • configured a switch that succesfully control PDC;
  • configured an utility sensor where I read when I have an instant solar excess production. Such sensor shows current power watts which is < 0 when I export energy and is > 0 when I import energy.
I have tried to configure an event but I'm not satisfied.
I would like to implement through events such automatic behaviour
  • Switch on the PDC when there is power is < -1000 (I'm exporting energy with instant power of at least 1000 Watt)
  • Keep the PDC on even if instant power is > -1000 for at least 3 hours.
  • Switch off the PDC when the istant power is > 1000 and at least 3 hours have elapsed from last power on.
Second objective:
Set up a virtual selector switch to manage the following behaviour:
  • Force the PDC switch to OFF.
  • Automatic PDC switch as described above.
  • Force the PDC switch to ON
jannl
Domoticz version: 2026.1.x
Re: Activate switch when there is solar excess production
Post by jannl »
Basically this looks quite easy in lua, so what is your question?
sovking
Post by sovking »
Lua is necessary or it can be done using just Events/blocky ?
The automatic behaviour implemented with blocky miss the part "run at least for 3 hours".
Then I don't know to implement Automatic/Force switch.
There is any way to use the existing interface to do this ? Or I have to to everything with Lua ?
Is better to use Lua or dzEvents for this task ?
Any suggestion about such Lua scripts ? Or any pointer to similar script already posted in this forum ?
