How to calculate daily usage from 2 phases of the electricity meter?
Ysbrand
Domoticz version: 3.6169
Post by Ysbrand »
I've just started with Domoticz and trying to get a feel for it. As I do not complete understand the entire structure (yes I did read quite a bit of documentation) I might overlook something basic.
I'm using rfxcom to read the value of my electricity meters. As there are 2 distinct phases, I want to obtain the total usage. For this I've created a dummy device and used the following script:
local fase1_dv = 'Electra Fase 1'
local fase2_dv = 'Electra Fase 2'
local electra_idx = 14
if devicechanged["Electra Fase 1"] then
        fase1 = otherdevices_svalues[fase1_dv]
        fase2 = otherdevices_svalues[fase2_dv]
        fase1_val = tonumber(fase1)
        fase2_val = tonumber(fase2)
commandArray['UpdateDevice'] = electra_idx .. '|0|' ..  string.format("%.0f" .. 1 .. " kWh", fase1_val + fase2_val)
print(commandArray['UpdateDevice'])
This produces the following result:
While it does display the total value of the 2 counters, it doesn't show the total usage for today (11.887).
Where are these values stored and how can I get the total assigned to the virtual sensor.
Thanks,
Ysbrand
EdwinK
Re: How to calculate daily usage from 2 phases of the electricity meter?
Post by EdwinK »
Something like this is what I was looking for. But couldn't quite figure it out.
How did you do the 2 counters for the two phases?
asjmcguire
Domoticz version: 3.5877
Post by asjmcguire »
EdKo66 wrote:Something like this is what I was looking for. But couldn't quite figure it out.
Just in case you haven't figured this out yet - (this is my understanding - someone else might need to clarify if it is correct).
The daily reading is kWh (kilowatt-hours).
If a kettle says on the label it consumes 2.8kW (or 2800W) that means it uses 2800W in 60 minutes (per hour).
This means that it uses 2800/60 = 46.6W per minute.
So now let's assume we have a cumulative reading of 6.123kWh (which will be 6123 in svalue domoticz) and we are consuming 1.25kW at the time of the reading.
cumulative = 6123 + (1250/60) = 6143.833
svalue=1250;6143.833
You don't calculate the daily reading - Domoticz does that for you when you start feeding it with the increasing cumulative total.
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
