Fibaro FIBEFGMS-001-ZW5 5G 4-in-1
Eremit
Post by Eremit »
Hello Domoticz users,
since 2 weeks I am a new user to Domoticz.
This is my first post because I have a lot of problems with the Fibaro Multisensor.
I use an AEON USB Stick as controller:
And I can see the motion sensor two days:
But I have no device inside the device list.
I also changed the configuration line in config:
cd /home/pi/domoticz/Config/ --> (Is this the original Config folder?)
and changed the line in the file "manufacturer_specific.xml"
<Product type="0801" id="1001" name="FGMS001 Motion Sensor" config="fibaro/fgms001zw5.xml" />
I used the following side for informations:
viewtopic.php?t=14425
with this template config:
fgms001zw5.xml
(17.77 KiB) Downloaded 88 times
But without success.
I use Domoticz 3.5877.
What can I do now?
Eremit
Eremit
Re: Fibaro FIBEFGMS-001-ZW5 5G 4-in-1
Post by Eremit »
Update logfile:
2016-12-22 12:00:02.708 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-12-22 12:00:02.709 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-12-22 12:00:02.709 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2016-12-22 12:00:02.709 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 25
2016-12-22 12:00:02.709 OpenZWave: Value_Added: Unhandled Label: Seismic Intensity, Unit:
2016-12-22 12:00:02.711 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2016-12-22 12:00:02.711 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2016-12-22 12:00:02.712 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2016-12-22 12:00:02.712 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Burglar, Instance: 1
2016-12-22 12:00:02.713 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-12-22 12:00:02.715 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR ALARM, Label: General, Instance: 1
2016-12-22 12:00:16.938 OpenZWave: Received timeout notification from HomeID: 4225961877, NodeID: 3 (0x03)
But the state is the same. I can not see the device in the list.
Eermit
Eremit
Post by Eremit »
OK.
I found the problem in front of the computer.....
But I can not see the temperatur of the motion sensor.
Eremit
