Split at "temp/hum" sensor into separat hum and temp devices?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Ok, I Run Impreihome and it i not possible to change the icon for temp/Humidity devices, but it is possible on just temp sensors. (Weird, but that's how it is).
therfor I want to split ut my hum/temp sensors, or transfer the temp data to a dummy, same for Humidity.
Is this posible in a way?
Uten navn.png (51.21 KiB) Viewed 5325 times
mark.sellwood
Re: Split at "temp/hum" sensor into separat hum and temp devices?
Post by mark.sellwood »
I do this with my Oregon Scientific Thermometer & Humidity Sensor Remote Sensor & Aeotec Multi Sensor to split out the Thermometer & Humidity in to separate values.
The script below I use to split my Oregon & Aeotec but it may not work for you as it depends on the format of the raw data from the sensor, the Oregon & Aeotec both send there data in different formats.
The Oregon gets reported as temp;hum so they are split based on a match, where as the Aeotec reports as something different.
I know it took me some time with trial & error to get it working.
First you need to add the new virtual Temperature & Humidity sensors, make a note of there idx's
In the script you define the idx's of the virtual sensors to update.
eg local FGTidx = 166 --idx of virtual temp sensor "Front Garden Temperature"
"Front Garden" is the name of my Oregon sensor & "Lounge" is the name of the Aeotec sensor
local Front Garden Temperature idx = 166 --idx of virtual temp sensor "Front Garden Temperature"
local Front Garden Humidity idx= 167 --idx of virtual humidity sensor "Front Garden Humidity"
local Lounge Temperature idx= 200 --idx of virtual temp sensor "Multi Sensor 1 Temperature"
local Lounge Humidity idx= 201 --idx of virtual humidity sensor "Multi Sensor 1 Humidity"
time = os.date("*t")
if((time.min % 10)==0)then
	function round(num, idp) -- Credits go to Martin Rourke, I used his function.
		local mult = 10^(idp or 1)
		return math.floor(num * mult + 0.5) / mult
-- Split Oregon
sWeatherTemp, sWeatherHumidity = otherdevices_svalues['Front Garden']:match("([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp)
commandArray[1]={['UpdateDevice'] = Front Garden Temperature idx .. '|0|' .. tostring(sWeatherTemp)}
sWeatherHumidity = tonumber(sWeatherHumidity)
commandArray[2]={['UpdateDevice'] = Front Garden Humidity idx.. '|' .. (sWeatherHumidity)  .. '|0'}
--Split Aeotec
MS1Temperature = round(otherdevices_temperature['Lounge'])
commandArray[3]={['UpdateDevice'] = Lounge Temperature idx.. '|0|' .. tostring(MS1Temperature)}
MS1humidity = otherdevices_humidity['Lounge']
commandArray[4]={['UpdateDevice'] = Lounge Humidity idx.. '|' .. (MS1humidity)  .. '|0'}
Please note that this is a Time script & it runs every 10 mins.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Evelen
Post by Evelen »
thanks for replay, have modified the script a little but noting i happening, just errors in console.
2016-12-21 23:33:00.194 Error: EventSystem: in Temp/Fukt Splitter: [string "local temperature_dummy_idx = 233 ..."]:16: expected near 'end'
Running the scripts as "time" without det time-function inckluded (so every minute.
local humidity_dummy_idx =      234
-- Split
sWeatherTemp, sWeatherHumidity = otherdevices_svalues['3 - Stue/Kjøkken']:match("([^;]+);([^;]+)")
commandArray[1]={['UpdateDevice'] = temperature_dummy_idx .. '|0|' .. tostring(sWeatherTemp)}
commandArray[2]={['UpdateDevice'] = humidity_dummy_idx.. '|' .. (sWeatherHumidity)  .. '|0'}
Devices:
"3 - Stue/Kjøkken" = idx 15 <-this one is the real device
"3 - Stue/Kjøkken - Luftfuktighet" = idx 234
"3 - Stue/Kjøkken - Temperatur" = idx 233
idx 15:
Current state: 23.6;30;2
sValues: 23.6;30;2
idx 234 (dummy):
Current state: 1
sValues: 1
idx 233 (dummy):
Current state: 0.0
sValues: 0.0
Any idea?
mark.sellwood
It looks as if your sensor is returning 3 bits of data (23.6;30;2) so I think you may need to edit the following line
existing
New
sWeatherTemp, sWeatherHumidity, sWeatherOther = otherdevices_svalues['3 - Stue/Kjøkken']:match("([^;]+);([^;]+);([^;]+)")
I know it took me a couple of days to sort it out with much trial & error.
briped
Post by briped »
I wanted to split my sensor values for a couple of reasons:
  1. Easier to replace a device in Domoticz (and retaining the log) when you don't have to worry about getting a TempHum to replace your previous TempHum. Now I can just split the values into dummy devices and then update the script with the new hardware devices.
  2. 2. Friendly sensor names for the Dashboard. I like to give my sensors longer and more descriptive names, but it doesn't look pretty on the Dashboard.
Using the examples in this thread (and other resources), I came up with this
-- Balcony
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['Sensor1 (Clas Ohlson 36-4441)']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Balcony Temperature'], sensorTemperature) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['Balcony Humidity'], sensorHumidity, sensorHumidityStatus) })
-- Bathroom
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['Sensor2 (Oregon THGR810)']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Bathroom Temperature'], tonumber(sensorTemperature)) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['Bathroom Humidity'], sensorHumidity, sensorHumidityStatus) })
-- Bedroom
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['Sensor3 (Aeotec ZW100)']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Bedroom Temperature'], sensorTemperature) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['Bedroom Humidity'], sensorHumidity, sensorHumidityStatus) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%d", otherdevices_idx['Bedroom Lux'], otherdevices_utility['Sensor3 Lux (Aeotec ZW100)']) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Bedroom UV'], otherdevices_uv['Sensor3 UV (Aeotec ZW100)']) })
-- Closet
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Closet Temperature'], otherdevices_temperature['Sensor4 (Clas Ohlson 36-4744)']) })
-- Hallway
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Hallway Temperature'], otherdevices_temperature['Sensor5 (Clas Ohlson 36-4744)']) })
-- Living Room
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Living Room Temperature'], otherdevices_temperature['Sensor6 (Clas Ohlson 36-4744)']) })
-- Refrigerator/Kitchen
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['Sensor7 (Clas Ohlson 36-4441']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['Refrigerator Temperature'], tonumber(sensorTemperature)) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['Kitchen Humidity'], sensorHumidity, sensorHumidityStatus) })
A thing to note (which I see was also part of the issue in the above posts) is that a humidity sensor uses the nValue for humidity percentage and the sValue for the "feeling" (or "status" as it's referenced in the API/JSON wiki), whereas the temperature sensor uses the sValue only.
To be certain I understood the UpdateDevice event syntax correctly, I had to verify in the domoticz source code, where I confirmed that index 0 was the idx, index 1 is the nValue and index 2 is the sValue:
['UpdateDevice'] = idx|nValue|sValue
Also, using the "string.format" you have to keep in mind to use the correct types. In my example I've only used "%d" (digit/integer) and "%f" (float/decimal number). When using floats you can specify how many decimals like this; "%.2f" for 2 decimals, "%.5f" for 5 decimals etc. "%s" is a string (anything enclosed in 'single' or "double" quotes essentially). I forgot this in the beginning so I kept getting my temperature as integers (3 rather than 3.5 f.ex).
And one last thing. Dumping all variables to the log is really helpful when trying to figure out what devices/events is available and what values they contain.
funnybu
Domoticz version: 3.9272
Post by funnybu »
My be someone has Dzvents example for this action? Split at temp/hum sensor into separate hum and temp devices?
funnybu
Post by funnybu »
It's me
DzVents script
local REAL_TEMP_HUM_DEVICE = 'outdoor_temp_hum' -- Real temperature and humidity device name
local DUMMY_TEMP_DEVICE = 'outdoor_temp' -- Dummy temperature device name
local DUMMY_HUM_DEVICE = 'outdoor_hum' -- Dummy humidity device name
        on = {devices = {REAL_TEMP_HUM_DEVICE}},
        logging = {
                    level = domoticz.LOG_ERROR,
                    marker = "temp_split"
        execute = function(dz, trigger )
            local virtualTemperatureSensor  = dz.devices(DUMMY_TEMP_DEVICE)
            local virtualHumiditySensor     = dz.devices(DUMMY_HUM_DEVICE)
            local masterTemperature         = dz.utils.round(trigger.temperature,1)
            local masterHumidity            = dz.utils.round(trigger.humidity)
            local masterHumidtyStatus       = trigger.humidityStatusValue
            local slaveTemperature          = dz.utils.round(virtualTemperatureSensor.temperature,1)
            local slaveHumidity             = dz.utils.round(virtualHumiditySensor.humidity)
            if slaveTemperature ~= masterTemperature then
                virtualTemperatureSensor.updateTemperature(masterTemperature)
            if slaveHumidity ~= masterHumidity then
                virtualHumiditySensor.updateHumidity(masterHumidity,masterHumidtyStatus)
Harald777
Domoticz version: Latest
Post by Harald777 »
Hi guys,
I want to only use the temp and hum value of a multi sensor (tem, hum & baro) but cannot get that to work.
The sensor has THB1 - BTHR918, BTHGN129 as type description (Temp + Humidity + Baro).
Its a home weather station sensor and the baro value is very unreliable while temp and hum are okay.
Any tips on how to do that is much appreciated.
Greetings,
Harald
Harald777 wrote: Sunday 27 October 2019 18:38 I want to only use the temp and hum value of a multi sensor (tem, hum & baro) but cannot get that to work.
What is unclear about the previous post ? @funnybu already shared a script to split the values and update a new virtual device with these values.
Harald777
Post by Harald777 »
Unfortunately not that clear to me. Will do some more investigation.
Verstuurd vanaf mijn Nexus 5X met Tapatalk
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
thanks funnybu
just got my Digoo R8S sensor and implemented your script.
seems to be working nicely. at first it did not update but now it does
