milight and rflink
12345caravan
milight and rflink
Post by 12345caravan »
I got an rflink and 1 milight ledstrip controller and one 6w rgbw bulb.
Both are working with the milight remote as it should, ledstrip button 1 and bulb button 2.(rgbw,dimming all works)
But in domoticz with rflink as I turn on the bulb the ledstrip is also turned on..... but in domoticz the switch says it's out...
Looks like rflink is grouping the milights, can't figure out why?
Edit: firmware R45 solved my problem, for anyone having the same issue. ;)
sincze
Domoticz version: 2024.4
Re: RE: milight and rflink
Post by sincze »
12345caravan wrote:I got an rflink and 1 milight ledstrip controller and one 6w rgbw bulb.
I have this exact same thing indeed just moved to R45 to see if it fixed my problem as well. Thanks for noticing.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
