Force off to rfxcom device even if state is off in domoticz
Posted: Tuesday 13 December 2016 23:21
Hello
I´ve some shutter controlled by DIO rfxcom device
If I control the device by the local switch domoticz does not catch
The command so that it doesn't update the off to on status
So I can have a shutter opened (should be on in domoticz) with a status at off in domoticz
In that case In blocky the set device = off doesn't send the off command because it believe it is already off
How can I do either to have the correct status in domoticz or
To force the off in blockly even if the state is already off ?
