Hello
I´ve some shutter controlled by DIO rfxcom device
If I control the device by the local switch domoticz does not catch
The command so that it doesn't update the off to on status
So I can have a shutter opened (should be on in domoticz) with a status at off in domoticz
In that case In blocky the set device = off doesn't send the off command because it believe it is already off
How can I do either to have the correct status in domoticz or
To force the off in blockly even if the state is already off ?
Force off to rfxcom device even if state is off in domoticz
multinet
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
6 sondes DS18B20
- Egregius
- Domoticz version: v2024.7
Re: Force off to rfxcom device even if state is off in domoticz
Don't use the local switch
Or use a zwave device that sends it's state.
Or update the switch to off on a time.
multinet
Zwave is the good solution for sure but I will migrate to it Amin 2017
I found a trick in blockly : set on and then set off seems to work (force off to device even if the state if already off in domoticz)
6 sondes DS18B20
6 sondes DS18B20
