I've just added an OTGW to my setup and while I have managed to add the hardware and can see numerous new devices associated with this, I was wondering how I can get to add/see the following:
Burner starts
CH Pump starts
DHW Pump/Valve starts
DHW Burner starts
Burner Operation hours
CH Pump Operation hours
DHW Pump Operation Hours
DHW Burner Operation Hours
...and any of the other data being reported/collected
I've looked at the message string and they are included, are being parsed in the code, but I think (from my limited ability) no devices are created (possibly for good or logical reason). Anyone got some insights on this?
Devices for Burner Starts & Hours, Pump Starts & Hours
kompio
Re: Devices for Burner Starts & Hours, Pump Starts & Hours
I have this same problem, Domoticz not add devices automatly. For examples : Burner starts.
I have only this:
Max_CH Water Setpoint
DHW Setpoint
Return Water Temperature
Outside Temperature
DHW Temperature
Boiler Water Temperature
Room Temperature
Room Setpoint
Maximum Relative Modulation Level
Control Setpoint
DiagnosticEvent
CH2_Active
Cooling_Mode_Active
FlameOn
DHW_active
CH_active
Fault_indication
CH2_enabled
OTC_active
Cooling_enable
DHW_enabled
CH_enabled
GPIOBStatusIsHigh
GPIOAStatusIsHigh
GPIOBPulledToGround
GPIOAPulledToGround
I have only this:
DHW Setpoint
Outside Temperature
DHW Temperature
Room Temperature
Room Setpoint
Control Setpoint
DiagnosticEvent
CH2_Active
Cooling_Mode_Active
FlameOn
DHW_active
CH_active
Fault_indication
CH2_enabled
OTC_active
Cooling_enable
DHW_enabled
CH_enabled
GPIOBStatusIsHigh
GPIOAStatusIsHigh
GPIOBPulledToGround
GPIOAPulledToGround
