Blocks in events not working wel
Posted: Thursday 08 December 2016 21:28
by berthwk
When i make an event in domoticz to send out a message if the front door is open it wont work
Build it like this
- knipselvraag.JPG (47.4 KiB) Viewed 1084 times
The event is active and saved.
When i choose to remove the part after and it wil work ans send a message.
Need some help to get it working.
Re: Blocks in events not working wel
Posted: Thursday 08 December 2016 21:30
by Flopp
Try to use email function and see what happens
Posted: Thursday 08 December 2016 21:37
by berthwk
And why do you think e-mail is not the solution for this problem? it is strange that the options after the "and" arguments en before the send arguments seems not to work good.
setting up the blocks like this
- vraag2.JPG (20.04 KiB) Viewed 1079 times
and on the phone i will recive the message.
Posted: Thursday 08 December 2016 21:41
by Flopp
I see the problem, and, must be between the arguments
Posted: Thursday 08 December 2016 21:47
by berthwk
You meen like this ?
- vraag3.JPG (29.68 KiB) Viewed 1077 times
That is the same as
- knipselvraag.JPG (47.4 KiB) Viewed 1077 times
the only thing is that the block is set as external inputs.
And the results are the same
Posted: Thursday 08 December 2016 21:48
by Flopp
Ok. Then it might be a bug
Posted: Thursday 08 December 2016 22:22
by StanHD
Just a thought, is it worth trying "on" instead of "open" for the door status?
Posted: Thursday 08 December 2016 22:47
by berthwk
Tried that option already.
Looking at the status of the device ( a sensative strip ) it is working with open and close
