Blocks in events not working wel
berthwk
Post by berthwk »
When i make an event in domoticz to send out a message if the front door is open it wont work
Build it like this
The event is active and saved.
When i choose to remove the part after and it wil work ans send a message.
Need some help to get it working.
Flopp
Re: Blocks in events not working wel
Post by Flopp »
Try to use email function and see what happens
berthwk
Post by berthwk »
And why do you think e-mail is not the solution for this problem? it is strange that the options after the "and" arguments en before the send arguments seems not to work good.
setting up the blocks like this
and on the phone i will recive the message.
Flopp
Post by Flopp »
I see the problem, and, must be between the arguments
berthwk
Post by berthwk »
You meen like this ?
That is the same as
the only thing is that the block is set as external inputs.
And the results are the same
Flopp
Post by Flopp »
Ok. Then it might be a bug
StanHD
Post by StanHD »
Just a thought, is it worth trying "on" instead of "open" for the door status?
Python:- Broadlink RM2, Sonos
berthwk
Post by berthwk »
Tried that option already.
Looking at the status of the device ( a sensative strip ) it is working with open and close
